No Spark
No Spark
Hello 98 Blazer is acting up for two weeks when the motor gets to about 180 it would cut out just die and you could restart drive a little farther and it would die again after 4-5 times it would not restart no spark. Let it cool down and it would restart. I changed all sensors still the same. I discovered the crank sensor hitting reluctor wheel. So I changed the front cover because it was a dorman, ATP or Pioneer to GM cover and the oil Pan gasket. I took the front axle out so after I got the engine all bolted up and sealed I started the Blazer it ran prefect for 15 mins as I was getting the air pocket out of cooling. Turned Blazer off and installed axle and all the rest of the parts. Tried to restart and no spark. I have changed the cam sensor in distributor, the coil, CSP sensor and ICM I am at a loss. I have seen the post for wiring diagram to pcm for 96 but am not sure which connector of the 4 it is. How can I tell if the PCM is bad now?
I have found a DTC P1626 Theft Deterrent Fuel Enable Signal Not Received code now after disconnecting battery to finish hooking up 4 wheel actuator under battery and reconnecting battery to get no spark and this code. How to reset?
After a long day off rechecking everything I did and ohm's reading all the wiring back to PCM for the crank, cam sensor, Ignition control module. Started the truck and it ran so I started to play with all the wires to everything and found the Ignition Control Module terminal plug to be faulty. I guess from all the heat the Ignition Control Module generates it has distorted the plugin because I have two modules and both stall out when terminal is wiggled.
JavierEscalonJr
10-14-2020 11:38 PM
abe_f
04-01-2013 11:19 PM
Yankee Team1020
23
08-03-2011 08:05 AM
