No spark help please
Old Oct 1, 2013 | 04:36 PM
billyboy2287's Avatar
billyboy2287 is on a distinguished road
Default No spark help please
Buddies blazer...97 4.3 4x4 I believe its edi. Died while he was driving it tested for fuel and spark. Shot some fuel in the intake and nothing. Took the coil wire off and no spark. I tested the pink wire and got no voltage. Now behind my back he bought a crank sensor and new coil and it still didnt start pretty crazy huh lol. Anyway is there a fuse or circuit I need to check next or is it the pcm??? Thanks you guys
Old Oct 1, 2013 | 05:04 PM
burned's Avatar
burned is on a distinguished road
If your not getting 12 volts on the pink wire with the ignition on and the meter grounded then check the ECM IGN Fuse 10
Old Oct 1, 2013 | 06:33 PM
If thats in the fuse panel in the truck then they are all good..
Old Oct 2, 2013 | 02:10 PM
All fuses are good still no power. I did just notice the instrument panel is not working with the ignition on or while cranking it. The only thing left it could be is the ignition switch right/?? Come on all these views and no replies.
Old Oct 2, 2013 | 03:11 PM
spittybays
Guest
Posts: n/a
Read this, it might help.
https://blazerforum.com/forum/2nd-ge...o-start-52956/
PS, 97 ignition switch has history of crapping out.
Old Oct 2, 2013 | 03:18 PM
Well I tapped on the ignition switch 20 times the 21st time the gauge cluster came on and I knew at the point it would start and it did !!! I will read the article you posted thank you. One last thing the voltage is maxed out I think at 16 volts is the regulator built into the computer or is it in the alt?
Old Oct 2, 2013 | 03:22 PM
I wish you would of posted that sooner it would of been a huge help lol. Either way thank you! I did use the search function on here but did not come across it.
Old Oct 2, 2013 | 06:58 PM
spittybays
Guest
Posts: n/a
No boo's from the search function lovers. I find the google box on the homepage to be much more helpful. I typed in "cluster dead no start" and that was the first bf article that came.
bb sorry I couldn't have done it faster but I was busy with a blown brake line....fixed
JavierEscalonJr
Oct 14, 2020 11:38 PM
blazzer
Jun 4, 2013 04:40 PM
abe_f
Apr 1, 2013 11:19 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
rogggg1020
Nov 11, 2008 08:05 AM
