No start issue
https://www.youtube.com/watch?v=8Zp0...ature=youtu.be
thats the issue im dealing with i was driving and my car shut off and now wont start, i checked fuel pressure via schrader valve, and i got nothing tried the fuel pump relay same thing, is this a fuel pump issue? i couldn't hear it pump when i turned the key on |
if you cant hear the pump and there is nothing at the schrader valve then yes I would say the pump is shot, But have you checked that the emergency shut off switch hasn't tripped or the relay under the hood? you could try hitting the bottom of the tank with a rubber mallet ,if the pump kicks in then you can move it if you have to?
Originally Posted by canuck blazer
(Post 630017)
i stand corrected chevy apparently does not use them only the relay so i would say change the pump
1 Attachment(s)
I would say before go dropping tanks and pulling pumps check to see if you have power back there with a multi meter. Nothing as much fun as dropping the tank and have it not work!
What year is your truck. There can be two spots you can jump 12v to the pump. Attachment 31285 This pic is courtesy of Captain Hook, if you put 12v to it you should hear the pump run and read 12v back at the pump. If you have an older one like me under the hood on the port side over the wheel well by the power supply you will see a 10 or 12 gage red wire with a quick disconnect just looking like it has no place to go. That's the fuel prime. Put 12v to that and see if you get anything to the back. Another thing to check is the black wire from the pump to the frame. Should be less then five ohms resistance (perfect world) You need to go to homepage find the sticky that reads 96 fuel system diagnosis. Good Luck, Spittybays............. |
1 Attachment(s)
Originally Posted by spittybays
(Post 630032)
What year is your truck. There can be two spots you can jump 12v to the pump. https://blazerforum.com/forum/attach...ine=1404182770 This pic is courtesy of Captain Hook, if you put 12v to it you should hear the pump run and read 12v back at the pump. If you have an older one like me under the hood on the port side over the wheel well by the power supply you will see a 10 or 12 gage red wire with a quick disconnect just looking like it has no place to go. That's the fuel prime. Put 12v to that and see if you get anything to the back. Another thing to check is the black wire from the pump to the frame. Should be less then five ohms resistance (perfect world) You need to go to homepage find the sticky that reads 96 fuel system diagnosis. Good Luck, Spittybays............. |
anyone know what sizze bolts the straps are so i can purchase new ones?
new straps and hardware are cheep, even at the stealership
Ok this is a ridiculous question but how the F&*^ do you post a question. Thought i looked everywhere but must have missed something
Originally Posted by 10-78 edac
(Post 630141)
