No start issue
Old Jun 29, 2014 | 08:44 PM
jmpx55x's Avatar
jmpx55x is on a distinguished road
Default No start issue
https://www.youtube.com/watch?v=8Zp0...ature=youtu.be
thats the issue im dealing with i was driving and my car shut off and now wont start, i checked fuel pressure via schrader valve, and i got nothing tried the fuel pump relay same thing, is this a fuel pump issue? i couldn't hear it pump when i turned the key on
Old Jun 29, 2014 | 11:10 PM
canuck blazer's Avatar
canuck blazer is on a distinguished road
if you cant hear the pump and there is nothing at the schrader valve then yes I would say the pump is shot, But have you checked that the emergency shut off switch hasn't tripped or the relay under the hood? you could try hitting the bottom of the tank with a rubber mallet ,if the pump kicks in then you can move it if you have to?
Old Jun 29, 2014 | 11:33 PM
jmpx55x's Avatar
checked the relay under the hood it was good switched it with the horn one. but where is the emergency shut off switch? i havent checked that yet im 99 percent sure its the pump but want to exhaust all other options before dropping the tank tomorrow
Old Jun 30, 2014 | 09:06 AM
i stand corrected chevy apparently does not use them only the relay so i would say change the pump
Old Jun 30, 2014 | 10:01 AM
spittybays
Guest
Posts: n/a
I would say before go dropping tanks and pulling pumps check to see if you have power back there with a multi meter. Nothing as much fun as dropping the tank and have it not work!
What year is your truck. There can be two spots you can jump 12v to the pump.
This pic is courtesy of Captain Hook, if you put 12v to it you should hear the pump run and read 12v back at the pump. If you have an older one like me under the hood on the port side over the wheel well by the power supply you will see a 10 or 12 gage red wire with a quick disconnect just looking like it has no place to go. That's the fuel prime. Put 12v to that and see if you get anything to the back. Another thing to check is the black wire from the pump to the frame. Should be less then five ohms resistance (perfect world)
You need to go to homepage find the sticky that reads 96 fuel system diagnosis.
Good Luck, Spittybays.............
Old Jun 30, 2014 | 09:46 PM
jmpx55x's Avatar
i ended up droppin the tank got it all down and out, ended up just cutting the straps and cutting the vapor hose on the front, but anyways i shall have the new pump in tomorrow and it back running hopefully if not i will light it on fire
Old Jul 1, 2014 | 07:51 PM
jmpx55x's Avatar
anyone know what sizze bolts the straps are so i can purchase new ones?
Old Jul 1, 2014 | 09:57 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
new straps and hardware are cheep, even at the stealership
Old Jul 1, 2014 | 10:09 PM
Landis's Avatar
Landis is on a distinguished road
Ok this is a ridiculous question but how the F&*^ do you post a question. Thought i looked everywhere but must have missed something
Old Jul 1, 2014 | 10:32 PM
jmpx55x's Avatar
Do you know the size? I want to pick em up at a hardware store I can get me for like 10 cents if I know the size
brian79z
32
Feb 23, 2015 07:13 PM
99bblazer99
Jun 15, 2013 08:38 PM
J.R. Clay
Mar 16, 2011 12:33 AM
extreme
Jan 5, 2010 07:29 AM
speedfreak81
Dec 15, 2009 11:47 PM
