no turn sign or hazard lights
Old Nov 7, 2010 | 02:00 PM
dundeeboy's Avatar
dundeeboy is on a distinguished road
Default no turn sign or hazard lights
I have no turn signal or hazard lights I have checked all the fuses but cant find any fault. Can anyone advise where the flasher unit is on a 2001 blazer LT. I have stripped the dash out and also checked behind the glove box but I cant see it ? or can someone post a pic of a flasher unit or advise if it might be something else
Thanks
Old Nov 7, 2010 | 02:07 PM
It is very common for the hazard switch (part of the multifunction switch) to fail. It can be replaced independently for under $20. Check out the Tech Article (DIY) Index link in my signature for how-to's.
As far as the flasher module, it is located behind the glove box. The view below shows it's location. Check out THIS THREAD for some pictures showing how to drop the glove box out of the way. The flasher you are after is the one held in by the green strap in the last picture in that thread.
Old Nov 8, 2010 | 09:27 AM
dundeeboy's Avatar
Default No turning signal
swartikk thanks very much for your help I dropped the glove box but still cant find the flasher relay. On your pics it is clearly shown with the green strap but it does not appear in the same location on my blazer. Mine is a right hand drive Uk motor do you know if this makes a difference ? Your help would be very much appreciated
Thanks
Old Nov 9, 2010 | 05:54 PM
RHD would have been crucial information to provide... You are going to have to hope that another RHD member can help you. There is no RHD information in any of my references.
Turbotrad
Apr 17, 2015 09:17 PM
radiorara
Apr 14, 2011 03:04 PM
ghost
Sep 15, 2009 11:52 AM
zombiewoof
Feb 23, 2009 09:07 PM
rryker
Apr 25, 2006 04:14 PM
