no voltage present at purge solenoid or vent solenoid
Old Oct 10, 2009 | 08:51 AM
god_zilla00000's Avatar
god_zilla00000 is on a distinguished road
Question no voltage present at purge solenoid or vent solenoid
what do i do after no voltage at purge solenoid or vent solenoid?on evap system.
Old Oct 10, 2009 | 08:55 AM
Did you command them to open with a Tech2 or equivalent bi-directional scan tool? They do not have voltage under normal operating conditions. Only when the PCM commands them to open do they get energized.
Old Oct 10, 2009 | 09:11 AM
ya thats what i was wondering.the haynes book sez solenoid will not activate until fuel tank pressure exceeds 0.7 psi.But it sez test with ignition on not motor running.so i need a tech 2 to test ??
Old Oct 10, 2009 | 09:28 AM
You have to activate the solenoids. I know that my scan tool can open them by command.
Old Oct 10, 2009 | 09:44 AM
by the way this is on 98 4x4 4 door blazer
wonder if autozone rents scan tools ?
i manually put juice to the vent solenoid it seem to be in working order.couldnt blow or suck on it to see if air tight but i heard it working at least.
Last edited by swartlkk; Oct 10, 2009 at 10:35 AM. Reason: Merging Consecutive Posts - Please use the EDIT feature to add more information to your post if another member has yet to reply.
Old Oct 10, 2009 | 10:50 AM
You should remove them to assess their seal. Knowing that they can move is only half of the equation.
I do not know if autozone will have a scan tool capable of bi-directional control.
Old Oct 10, 2009 | 11:18 AM
i read in one of your older post to take it apart(vent solenoid)your seal was bad so you bought another one.i tried to dis asemble(vent solenoid)but could not get to the seal.but i sprayed wd-40 as u said to do in old post.i get your point maybe not air tight.i have been topping off my gas tank for several months now.just cause gas level sending unit bad.now reading in this sight it can be bad for the canister.could this be the problem?bed canister?and if so how do i test the canister.maybe its full of gas?
Old Oct 10, 2009 | 12:33 PM
If you remove the charcoal canister and, when tipped on its side, gas pours out, the canister is full of fuel and is not capable of performing its function in the system. You would either have to drain and then purge the remainder of the fuel out of the canister or replace it.
Old Oct 10, 2009 | 05:44 PM
thank u much.love blazer forum.not fixed yet but i will keep update on repair
Old Oct 10, 2009 | 05:52 PM
oh ya.....i pulled hose of bottom of canister no gas came out not even a little..must it be tipped like you said?not sure what the inside looks like.if their was gas in it as much as i thought seems like some gas would of came out.i thought the thing would of been full for all time times i topped of the gas tank.ty again for your info i am now headed in the rite direction.
