Noobie here. Need some help, 95 Blazer
Old Jun 29, 2011 | 07:49 AM
  #21
kristoph30's Avatar
kristoph30 is on a distinguished road
Originally Posted by kristoph30
I bet your idling problem is related to the braking issue. It sounds like your brake booster may have failed. That would make a HUGE vacuum leak. Plug the vacuum line between the brake booster and the intake manifold and see if that makes a difference with the idle.
You havent tried a free repair before you went and spent over a hundred bucks on a tune up?
Try the free stuff first!!!
Old Jun 29, 2011 | 08:42 AM
  #22
rival904's Avatar
rival904 is on a distinguished road
Where did you see I spebt 100 bucks? Ive only spent maybe 40 bucks on plug wires and egr gasket.
Anyways I did pop the vaccum line out, truck ran better but still rough with the vaccum hose off, I plug it with my thumb and the truck bogs back down and sounds same as before.
While I had the hose off I sprayed a quick squirt of carb cleaner down there, engine revd, put vaccum line back on, sprayed carb cleaner around the connections of the vaccum line and couldnt get it to rev. It revs fine with no sputtering or anything, just wont idle.
Old Jun 29, 2011 | 05:02 PM
  #23
kristoph30's Avatar
You had said you bought plugs, found a bad wire (So I assumed you replaced the whole set) and normally if I go through the trouble of replacing plugs and wires, I also replace the cap and rotor.. My bad for assuming you replaced all the ignition components.
Old Jun 29, 2011 | 05:06 PM
  #24
rival904's Avatar
I must have mis-typed, I never bought plugs, brand new ones were in when I purchased it. I replaced all plug wires, I did ordera cap and rotor from Rockauto(which wont be here till tommorrow).
Gotta run to the fedex store and Im going to go see if I cant figure this PITA out.
Old Jun 29, 2011 | 09:04 PM
  #25
rival904's Avatar
Ok after I few people saying to check the injector spider, I got bored and pulled the intake off.
This was the result
Old Jun 30, 2011 | 01:28 AM
  #26
kristoph30's Avatar
Looks like you found your problem!
Old Jun 30, 2011 | 01:36 AM
  #27
just plain lucky's Avatar
just plain lucky is on a distinguished road
yup the sensor thingy is connected to the bottom of the tube that goes to the air filter I remember when i put new thermostate in I took it apart to have more room to get to the thermostate... yup yup yup good luck feller your in a good spot lots of people will help you here so no worries enjoy later
Old Jun 30, 2011 | 01:46 AM
  #28
dude that was soo wierd I was going to write some thing and it ended up on someone elses post strange then I gave a little advice and figured my way back her hahahhahhah
ya dude the thing in your hand goes to the aparatas that goes to the air filter on the bottom of it I remove mine to get more access to the thermostat when I was replacing it ...
Good luck bra
Old Jun 30, 2011 | 09:14 PM
  #29
rival904's Avatar
And heres the puddles in the upper intake.
Old Jun 30, 2011 | 10:11 PM
  #30
NT_Hardcore's Avatar
NT_Hardcore is on a distinguished road
jesus man
