Is this normal ?
Old May 28, 2019 | 03:32 PM
jimmy_for_ever's Avatar
jimmy_for_ever is on a distinguished road
Post Is this normal ?
Hi everybody
When I see my oil pressure gauge I think that it is low but I am not sure.
Is this normal?
Old May 28, 2019 | 04:01 PM
Mike.308's Avatar
The question is more like "is it within the specification". To be more accurate check out 4.3 Vortec manual for pressure/rpms table. Most probably it is.
The engine is heated, so Your oil is thinner than when cold. That makes it flow easier through the block. Add the engine bearings wear and You'll get the picture as on photo...
To be on a safe side You may check the oil dipstick to see if the oil isn't mixing with coolant (will form the matter resembling butter). But if this is not a sudden change, then probably You don't have to worry much. Just check out when was Your last oil change.
EDIT: Oh, just noted You have a 300k kms on odometer, so probably this is an usual wear.
Old May 28, 2019 | 05:55 PM
If your idling, then your low
Old May 28, 2019 | 09:16 PM
cleburne red's Avatar
So, I'm not sure how those numbers relate to freedom units, but it looks pretty low to me. Mine has 338k miles, and it's significantly higher at idle than yours
Old May 29, 2019 | 05:27 AM
djh61187's Avatar
djh61187 is on a distinguished road
275 kPa is about 40 psi. So the half way mark between 0 - 275 should be around 20 psi. Your a bit under that. A little low on pressure looks like to me, But not horribly low for a 200,000 mile engine. What oil are you running?
Old May 29, 2019 | 07:23 AM
I use 5w-30 liqui moly Longtime High Tech
Old May 29, 2019 | 07:44 AM
LesMyer's Avatar
I apologize but as a Moderator I somehow wrote over your message when trying to reply and I ended up deleting the result. Please re-post
You can use 10W30 to make up for extra bearing clearances in a worn engine. the owners manual allows 10W30. good luck
Old May 29, 2019 | 08:04 AM
Mike.308's Avatar
According to the Vortec service manual You should have the following pressure at the normal operating temperature (heated up block):
6.0 PSI/42 kPa at 1k rpm
18 PSI/125 kPa at 2k rpm
24 PSI/166 kPa at 4k rpm
Btw. when was Your last oil change? Any chance for plugged filter?
Old Jun 1, 2019 | 01:58 AM
Post
I notice that as temp go up the oil pressure go down .
The last oil change was before 6 month but I am not really sure
Old Jun 1, 2019 | 08:49 AM
I'd say your a little over a quart low, check the dip stick, or do an oil change. Also check your remote oil lines, as you might be losing oil from there.
