np 233 not shifting
Old Sep 4, 2011 | 07:14 PM
ericjkeyes's Avatar
ericjkeyes is on a distinguished road
Default np 233 not shifting
This 98 Blazer is new to me. Trans and transfer were out when I got it. Trans appears to be gone through. Reassembled, started. Stays in 4wd lo. will not shift to 4 hi or 2 hi. Lights blink when pushed but shift motor not operating. Shifting motor "bumps" when shifting out of "park" other than that it will not move when any of the drive modes is selected.
Old Sep 4, 2011 | 09:01 PM
bromanjr's Avatar
bromanjr is on a distinguished road
In case you missed it, Transmission MUST be in Neutral and speed below 3MPH for any shifts into or out of of LO range. Hope that's all it is. If not you will probably need a scan tool that can diagnose the system.
Old Sep 4, 2011 | 11:10 PM
janddcunningham's Avatar
janddcunningham is on a distinguished road
Check your fuses mine did that and all it was was the blown fuse
Old Sep 5, 2011 | 12:38 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
I would pull the transfer case shift motor and manually shift the transfer case into 4-hi. I believe you need to turn the shaft clockwise. At least you can drive the thing.
Old Sep 5, 2011 | 11:36 AM
ericjkeyes's Avatar
Thanks guys, its hard to remember to include all the info when I'm writing whats wrong. Right now the Blazer is sitting on jackstands so under 3mph is no problem, I'll check the fuses this morn. I already pulled the shift motor to make sure it wasn't a mechanical problem. I spent most of the day yesterday and the day before reinstalling trans and transfer case and then getting it to start. Runs beautifully even after 3 years sitting. Former owner wasn't much of a mech so there is a lot to go through, 128k and I don't think much maintainance was done. Eric
cambow
Jun 14, 2010 10:51 PM
91chevywt
Mar 24, 2010 09:24 PM
mlprus
Feb 14, 2009 07:02 PM
mandng0
Feb 4, 2009 02:02 PM
mandng0
Oct 8, 2008 09:12 PM
