OBD 1.5 :( How do I obtain codes?
Old Jul 12, 2021 | 08:48 PM
  #21
Cresfonte's Avatar
Cresfonte is on a distinguished road
Default Same issue
Originally Posted by Gnfanatic
Hey guys, I tried searching and get conflicting reports. I verified it myself with the OBD1 sticker in the engine bay but I have a 16 pin port under the dash. My engine light is on and MPG is horrible. I want to get code but do not know how to. I have OBD2 scanners and they obv cannot help. Autozone says they cant do it either
help!
Did you find any solution? I have the same problem, I changed the distributor because the engine was knocking awfully, the cap was broken and the gear was worn out, after i did it, the check engine light pops up in the cluster and i don't know why. Tried to scan but the scanner doesn't work either... The truck works just fine, but it's still knocking at 60km/h about 3000rpm, although its less than before changing the distributor. Tomorrow i'm going to check the camshaft sensor of the new distributor and the knock sensor to see if its working.
Old Jul 12, 2021 | 10:08 PM
  #22
GeorgeLG's Avatar
What year is your truck?
George
Old Jul 12, 2021 | 10:35 PM
  #23
Cresfonte's Avatar
George
It's a 99 Chevy blazer, but apparently it doesn't have OBD2 connector.
Old Jul 12, 2021 | 11:29 PM
  #24
GeorgeLG's Avatar
Why do you say that it does not have an ODBII connector? It has the compliant ODBII 16 pin connector and a contact on pin 2 which is the J1850 serial communications pin for GM ODBII and its a 1999, well beyond the last year of ODB 1.5?
George
Old Jul 22, 2022 | 12:33 PM
  #25
hunter04's Avatar
hunter04 is on a distinguished road
jump pins 9 and 5 and you will get the check engine light to flash 12 3 times then the codes start coming if you have any.
David Wolstenholm
May 20, 2017 08:54 PM
Denominator
13
Oct 3, 2012 08:59 PM
mdemers2006
May 25, 2010 02:49 AM
NOs
Mar 28, 2010 09:06 AM
psewell@gvtc.com
Dec 23, 2009 07:49 AM
