how to jump for engine fault codes
Old Oct 15, 2009 | 11:05 AM
mdemers2006's Avatar
mdemers2006 is an unknown quantity at this point
Cool how to jump for engine fault codes
Hey all!
How to I check the fault codes on a 95 Blazer,4.3 ? It can be done with a paper clip but where do I jump it please? Last time I did that was 15 years ago on a Mazda B2002 .
I've searched for a tread about timing codes,etc... but no go
Many thanks in advance!!!
Mart
Old Oct 15, 2009 | 11:38 AM
rriddle3's Avatar
  1. Only 1995 models equipped with a PCM use the OBD I system. All other 1995 and later models use the OBD II system. The diagnostic trouble codes on 1995 OBD I systems can be read by grounding test terminal 6 . The terminal is most easily grounded by connecting it to terminal 5 (internal ECM ground).
  2. Once the terminals have been connected, the ignition switch must be moved to the ON position with the engine not running.
  3. The Service Engine Soon or Check Engine light should be flashing. If it isn't, turn the ignition OFF and remove the jumper wire. Turn the ignition ON and confirm that light is now on. If it is not, replace the bulb and try again. If the bulb still will not light, or if it does not flash with the test terminal grounded, the system should be diagnosed by an experienced driveability technician. If the light is OK, proceed as follows.
  4. The code(s) stored in memory may be read through counting the flashes of the dashboard warning lamp. The dash warning lamp should begin to flash Code 12. The code will display as one flash, a pause and two flashes. Code 12 is not a fault code. It is used as a system acknowledgment or handshake code; its presence indicates that the VCM can communicate as requested. Code 12 is used to begin every diagnostic sequence. Some vehicles also use Code 12 after all diagnostic codes have been sent.
  5. After Code 12 has been transmitted 3 times, the fault codes, if any, will each be transmitted 3 times. The codes are stored and transmitted in numeric order from lowest to highest.
Old May 25, 2010 | 02:49 AM
damoneric's Avatar
damoneric is on a distinguished road
Default similar issue
i had a similar issue in my chevy and on looking at the chevy engine codes i was able to rectify the issue.
Blazer95_4x4
Oct 1, 2012 01:14 PM
BlazinIowa
Feb 4, 2011 01:50 PM
jairriv
Mar 15, 2010 02:06 PM
LittleT
Oct 23, 2007 01:02 PM
dashyman
Mar 7, 2006 01:12 AM
