Obd 1.55?????????
Old Oct 5, 2019 | 09:12 AM
Kaintuck's Avatar
Kaintuck is on a distinguished road
Default Obd 1.55?????????
Ok.....story is...I DID ONCE with the paper clip deal.....now my abs light is on, and cannot remember which ports I used to get it to flash....even my mechanic couldnt get it to flash.....I don't wanna blow anything.....so who has this exact terminal, and can tell me which two to jump???.?.?.?.....
i have search the web.....and the answer hasn't been found, the jimmy is a 95, vortec engine, 4wd, anybody that can she'd light on this, I will play at your next wedding!!,!,!
HELP.......
Old Oct 7, 2019 | 05:20 PM
Kaintuck's Avatar
Any ideas???
it is a weird obd story!!!
Old Oct 8, 2019 | 07:57 AM
LesMyer's Avatar
Note color of wires for pins 5 and 6 below. Supposedly these are the ones you need to jumper on a 1995. Found this multiple times. Pin #5 is a ground. Pin #6 is supposed to be field service mode which makes sense for flashing a light if it is capable. Photo you show does not have a pin 6 but I really doubt if that is the actual connector on your vehicle (looks like a photo printed on a page that someone wrote on). I have zero experience with 1995 and only found this info through the internet, so your luck may vary.
So first make sure your sticker under the hood does NOT say OBD2 certification. Then unfasten the 16 pin connector from the dash so you can see the wires going into the different positions. Find the black w/white stripe wire and the white w/black stripe wire. Jumper these at your own risk. Better to use a capable scanner I think. Some old Actrons and the Tech 2 and others are supposed to work.
Note that second info below implies that pin 6 is not always present. If that is the case and you can't find the white wire w/black stripe, I don't see how you will get it to flash any codes.
Hope this helps
OBD1.5 16 pin /
pin4=Chasiss Grd.(Blk. Wire)
pin5=PCM Signal Grd.(Blk.W/Wht. Wire
pin6=160/canh+(Wht.W/Blk. Wire)
pin9=8192 (Tan w/Blk. Wire)
pin16=(12vdc)Orange wire
Jump 5+6 get code flashout, to clear out codes a scan
ner w/ OBD1/OBD2 protocals is needed with a GM
Specific (16 pin connector-Blue plug-in) or go to junk
yard and get a 12 pin ALDL and wire it like so.
( A to pin5, B to pin6, E to pin9, M to pin16)
Use the OBD1 connector on the 12 pin ALDL.
Old Oct 9, 2019 | 07:01 AM
Kaintuck's Avatar
les, that is my scribbles....my plug is exactly like this.....I can review what you sent, weird thing is, I did the paper clip thing years back....it blinked, I just didnt note it...duh, well, I've got a book started now!
this evening I will look at her with you diagram.....I'm just about ready to go to the Chevy dealership��
thank you....let's hope......
Old Oct 10, 2019 | 08:44 PM
Kaintuck's Avatar
Default Obd 1.55
Les, that's my photo and handwriting.....it's exactly what I have....which is pretty much worthless...dang Chevy engineers!!!
i will be able this weekend take your info and find out if it can work....the abs lights came on then would go off, I kept thinking my batt or alternator was bad....tested switched and tested again.....no rhyme or reason. Until.....the rear flex line broke....then we fixed it...and found the abs system brain was dead....so, replaced it with a salvaged unit....it works, but now this abs light stays on....maybe a speed sensor somewhere???....they can be checked/tested....but if we could code the 1st....🤗
anyways.....I'll keep going....she still has a solid motor and tranny....so the little bugs need worked out.....
thanks again.....marc
Old Oct 10, 2019 | 09:15 PM
odat's Avatar
I don't think the OBD 1.5 system is advanced enough for ABS codes - Its not really a OBD 1 or 2 kinnda in a throw back world of it's own .....
Old Oct 12, 2019 | 06:35 AM
Kaintuck's Avatar
How I know that!!!....
"what we have here....is a failure to communicate"������. I had no idea in 95 how important it is to have a complete working computer system....it's back to shade tree diagnostics......like my buddies 85 Porsche.....computer/relays/fuses....and 20 miles of wiring....one loose ground...system failure!!!!����☠️
Old Oct 12, 2019 | 06:40 AM
Kaintuck's Avatar
Odat....true true....."what we have here is a failure to communicate "��
i never thought it would be important to have a complete OBD system.....we were just happy to have our 1st new vehicle!
sigh...back to shade tree diagnostics...like my buddies 85 Porsche.....a nightmare of 1/2 computer relays fuses...and 20miles of wires...decades old����☠️��
Thnos
Nov 9, 2015 07:29 PM
chevyadore
Mar 28, 2012 11:24 AM
etsmith3
Feb 15, 2010 09:30 AM
cejay825
Oct 24, 2008 12:10 AM
catintat
Jan 31, 2008 07:54 PM
