OD puttom mod?
Old Aug 18, 2008 | 06:04 AM
Default RE: OD puttom mod?
ORIGINAL: djdrew010
Isn't OD off the back of the tranny, like a quarter of the size with an extra gear in it? or is there more than one type?
OD is an additional gear ratio that is built into the transmission, not something that is slapped on the back.
ORIGINAL: riceh8r0512
If you want a similar option but third party there is always the B&M Shift Plus. Granted the shifts are a lot firmer then with an OEM Tow/Haul, but it would do the same thing. That's what they designed the Shift Plus for, towing. Plus it is a two wire hook up
B&M Shift Plus only works for 93-98 trucks.
Old Aug 18, 2008 | 10:54 AM
riceh8r0512's Avatar
riceh8r0512 is an unknown quantity at this point
ORIGINAL: swartlkk
Not to argue with you, because the package does say 93-98 trucks, but if you read in theinstructions it says any vehicle with the M30or MT1RPO option. I just installed one on my buddies 2001 S-10, their directions only show up to those years, but you can still use it, works like a charm.
Old Aug 18, 2008 | 11:06 AM
It may work, but the programming was changed in 1999 on the 4L60E as well as some updates to the valve body. It very well may work, but may not be reliable in the long haul, hence why B&M does not endorse its use on 99 and later 4L60E equipped vehicles. There is always a reason for manufacturers to leave off model years.
Old Aug 18, 2008 | 01:33 PM
WolfPack's Avatar
I was looking at getting one from Jigg, and emailed him. If I recall, the write up on how to install the Shift Plus is on a 01 ZR2. Also I emailed B&M and they said it will work, but has not been tested extensively enough to include the model year.
So we should file that under 'use at your own risk'
Old Aug 18, 2008 | 02:42 PM
ORIGINAL: swartlkk
Would that explain why his would shift so much harder than mine? I mean mine gets it good, but it seems like his shifts so much harder. I thought it was weird that they would say all M30 RPO's but leave out models with it.
Old Aug 18, 2008 | 03:08 PM
That very well could explain it.
warthogdriver
Sep 4, 2013 12:10 PM
chris015
Engine & Internal
Jul 2, 2012 01:04 PM
2oooBlazer
Nov 17, 2009 08:09 PM
dobbist
Engine & Internal
May 1, 2005 04:02 AM
02 Vortech
Engine & Internal
Feb 23, 2005 03:59 AM
