Oil change
Old Apr 15, 2005 | 01:34 PM
DSRJohnGTP's Avatar
DSRJohnGTP is an unknown quantity at this point
Default Oil change
Hey guys, Im a newb here, my dad just picked up an 01 blazer and it seems like a pretty solid truck. Its about time for an oil change, how many quarts does it take? Its got the 4.3 vortec, 4x4. Also, where are the jack points?
Thanks.
Old Apr 15, 2005 | 04:27 PM
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
Default RE: Oil change
Jack points? I just crawl under on the ground LOL
I guess being little has it's perks.
I have a 4.3 as well, but mine's a 93. I use one jug of oil and I'm good.
Old Apr 15, 2005 | 11:15 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
about 5 quarts. and you can put the jack under the frame behind the front wheels and in front of the rear wheels. you can also put it under the rear differential to lift the whole rear up, but im not sure about the front. if there is a sturdy crossmember, then you can put it there
Old May 26, 2005 | 05:53 PM
curly2001's Avatar
curly2001 is an unknown quantity at this point
What size jugs?
Of oil and what brand?
Old May 26, 2005 | 10:06 PM
m00nwater's Avatar
I use a 4.4 L jug...I am guessing that is about 5 quarts like zero said. Not sure because that's the Canadian size. I think it's about 5 quarts though.
Old May 26, 2005 | 10:08 PM
m00nwater's Avatar
Oops...forgot to mention the brand. I usually use Castrol GTX, but I have been thinking of getting something a bit better since my truck's getting older. Any suggestions?
Hormisdas
Nov 27, 2012 09:42 PM
chris015
Jun 8, 2012 12:37 PM
zippy199
Oct 22, 2009 06:36 PM
todaresqSL2
Nov 10, 2008 01:47 PM
cimbali
May 28, 2006 08:59 PM
