Oil Filter Adapter
Oil Filter Adapter
Hi All,
I bashed the front end of my 1999 ZR2 into a dune the other day and broke the oil filter adapter and the hose from the adapter to the block. The hose is no issue to replace, it seems they are available everywhere, however, the oil filter adapter is the problem. Its cracked!
Does anyone have any experience in getting an oil filter relocation kit to work on a ZR2 without the factory fitted oil filter adapter? It seems they are very very hard to come by!
Thanks in advance!!!
There should be no reason why you couldn't. Just cut the rubber line and fit it to a hose barb connection then route the lines to the aftermarket oil filter relocation kit.
Thanks, any suggestions on good quality kits?
bajabound
02-16-2011 10:09 AM
