Oil Filter Housing Adapter Aluminum Galvanic Corrosion
Old Aug 15, 2015 | 09:13 PM
sledzepplin's Avatar
sledzepplin is on a distinguished road
Default Oil Filter Housing Adapter Aluminum Galvanic Corrosion
Car: 2005 Chevrolet Blazer Base Model 4WD
So much of this forum is people with problems (I have been one in the past) here is an issue I dealt with so hopefully it shows up the next time someone googles it:
I am inspecting my leaky remote oil lines and see this adapter housing (bolts on right corroded this bad, one on left broke during takeoff) and I had trouble finding parts!
Luckily it wasn't too hard to replace at the same time as my oil lines! I recommend doing the bracket(what it bolts too) at the same time as it is probably just as corroded and only ~$10 more according to the website.
I was in a rush so only replaced the housing and had to get it from Dorman
Schematic:
-Credit: Swartlkk
ENGINE OIL COOLER LINES
GM PART NUMBERS (not sure where made):
-Credit: Skibum458
Oil Filter Adapter 10236272
F-Bracket A: 15677626
Dorman Part Number (WARNING MADE IN CHINA):
Oil Filter Adapter 917-035
Dorman Products - 917-035
Other Thread: https://blazerforum.com/forum/2nd-ge...housing-66013/
Attached Thumbnails Oil Filter Housing Adapter Aluminum Galvanic Corrosion-nnhlzij.jpg   Oil Filter Housing Adapter Aluminum Galvanic Corrosion-njx4b48.jpg
LannyL81
Apr 18, 2013 09:50 AM
cahlersmeyer
23
Nov 10, 2011 09:23 PM
shamipacqu
Feb 18, 2009 05:37 PM
shamipacqu
buck
Feb 16, 2009 01:22 PM
