oil filter skid plate
Old May 17, 2010 | 10:37 PM
ricky's Avatar
ricky is on a distinguished road
Default oil filter skid plate
i have seen many blazers with the oil filter skid plate hanging down. any suggestions on how to fix this... already tried buying replacement nut/bolt fastener from dealer and the just broke off a couple days later.
Old May 17, 2010 | 11:24 PM
TreasonAgainstCaesar's Avatar
TreasonAgainstCaesar is on a distinguished road
You're talking about the oil filter access door on the skid plate hanging down?
I've never had a problem with mine. I've nearly destroyed the skid plate, but the door still functions properly. Are you sure you're turning the screw the right way? Can you post some pics of what the problem exactly is?
Old Jun 22, 2010 | 04:04 PM
th3m00s3's Avatar
th3m00s3 is on a distinguished road
i have a question about this also..mine's hanging down, and the bolt won't fasten to keep it from hanging down. however, on the door, there's something written like "door must be closed for engine cooling". is this something i need to be worried about? i dont see why it has to be closed (it's just a piece of plastic) other than just not to hang down when you drive and potentially hit something/break off.
Old Jun 23, 2010 | 11:52 PM
It's to direct airflow. It's not going to make a big difference if it's hanging down, but it's not a good idea to leave it that way. All you need is the little piece that it screws into. I don't know what it's called, but you can probably get something that would work at autozone in the helper section. If not, go to the junk yard and snag one off a skid plate there.
Old Jun 30, 2010 | 02:22 AM
4x4BlazerZR2's Avatar
4x4BlazerZR2 is on a distinguished road
Zip-tie it closed. Put on a new one when you change the filter.
Old Jul 2, 2010 | 03:11 PM
ricky's Avatar
omfg you are a genious why didnt i think of this earlier!!!!!!!!
Old Jul 5, 2010 | 08:17 PM
not to be a downer, but you're probably going to have to remove the skid plate to zip tie it each time. At that rate, I would just try to replace the part of the locking mechanism that is causing a problem.
Old Jul 6, 2010 | 06:50 PM
No, this is not the case. Simply put, thread the zip tie through the hole in the skid plate, then thread it through the hole in the door and tighten. I have never had to remove this skid plate to do this, and have done this plenty of times.
Sorry to take the wind out of your "down" wind sails.
Old Jul 7, 2010 | 11:56 AM
No need to apologize. Any time I can be proven wrong to help someone, I'll gladly do so.
I didn't realize this was something that you've actually done, I assumed this was just an idea. I didn't think you'd be able to properly thread it through both holes while the plate was on there.
jaq62
15
Jun 24, 2011 01:24 PM
Logan
Feb 17, 2010 09:12 PM
BlakeC23
Jan 25, 2009 09:00 PM
jim in texas
Oct 30, 2008 06:06 AM
TheBrettster
Oct 13, 2007 02:41 AM
