oil leak somewhere
Old Oct 25, 2011 | 10:29 AM
jdcapri's Avatar
jdcapri is on a distinguished road
Default oil leak somewhere
hi everyone i have a 97 blazer ls, and i noticed some drips on my driveway, so i got down and looked underneath the truck, and at the front u can see all sorts of stuff is soaked underneath, like the sway bars all wet the ball joints are kinda wet, i put my finger on the oil and confirmed it is red (tranny oil), i was just wondering are there hoses that go to the rad to cool the tranny oil? does anyone have an idea as to what this leak could be??....if u look in front of the front passenger tire thats where all the wetness is??? what should i do?
Old Oct 25, 2011 | 11:38 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
There most likely is a tranny cooler in your truck, and if there is then it will be on the right side of your radiator (passenger side) so i would assume that the lines run back along the passenger side of your truck. so it sounds like you are right in what you are thinking it could be, i would try to follow the lines back and see where its leaking from, but first and foremost check your tranny fluid level. i would find the area where the oil is the thickest, clean it and then check it again and you should find the leak. hope this helps
gitch93
Jul 30, 2013 09:04 PM
richphotos
Headers, Intake, & Exhaust
Jun 20, 2012 01:51 AM
ComputerNerdBD
Oct 26, 2011 09:33 PM
2000_BlzrLT
Jul 15, 2008 10:48 AM
kleijaker
Oct 24, 2007 06:08 AM
