Oil Pan Gasket Replacement
Hate to revive an old thread here but into doing a new pan gasket. I checked for any loose bolts and found none. My leak was right in front and center at the bottom of the timing cover. My ? is how clean does the factory sealant need to be especially at the front and rear arches. Felpro says to use just a pea size of sealant at the 4 points.
Any real experiences out there? Any tips on reassembly?
Old school rule of thumb was to apply a coat of rtv on both sides of the arch gaskets, a skim coat too the pan gasket and then a pea sized drop in the four corners - We did a 97 LS 4.3 rebuild two winters ago and we read the instructions with the Felpro gaskets and per instructions installed dry with the pea sized drops in the corners - yup they leaked - knocked the pan loose and applied RTV no more leak - Some where in this sight is a post that this was discussed and if memory serves me correct when contacted Felpro stated that the reason they advised dry is people was applying too much RTV and causing gasket problems - sometimes old school ways are better
My drip was at the front also so on the reseal I coated the front arch and skimmed a few inches back on the pan gasket its self and the pea drops, I would have skimmed the whole pan gasket but with motor installed I couldn't coat any farther back and I really wasn't into pulling the engine back out inless I had too
With mine the drip would puke out about a pint+ in about 10 to 15 min at a idle so i really didn't have a choice and I hate a leak on a fresh rebuild - My old 84 2.8 first gen 4x4 leaks out about a qt and a half too two qt's per oil change - I think it oozes out every seam she has, good ol work horse tho, run her hard put her away wet and she fires up to do it all over again when ever i need her
kevin turner
Apr 9, 2010 01:21 PM
AaronGene02
Jan 24, 2010 11:38 AM
