Oil pressure measurement
Old Nov 4, 2009 | 09:54 PM
blzR's Avatar
blzR is an unknown quantity at this point
Default Oil pressure measurement
May i ask just what should be the reading on my dash's oil pressure gauge when engine is hot on my 1995 blaz.
At present when started from cold it goes up passed 275(ilde),when it is hot(20mins)
at idle it is in between the 4th&5th bars/ticks from '0'.
Hope that makes sense.
thx!
Old Nov 4, 2009 | 10:26 PM
rriddle3's Avatar
Originally Posted by blzR
...At present when started from cold it goes up passed 275(ilde)...
275? Are you sure you're looking at the oil pressure gauge and not the engine temperature gauge?
Old Nov 4, 2009 | 10:52 PM
blzR's Avatar
rridle3Wrote:"275? Are you sure you're looking at the oil pressure gauge and not the engine temperature gauge?
For certain i am looking at the right gauge,and yep 275 when cold.(275 is half ways up on the gauge,it goes down 1/4 of the gauge when hot.)
Is 1/4 on the gauge to low when at idle with engine hot? (10w30 motor oil)
Old Nov 4, 2009 | 11:55 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
is this like a canadian blazer in like kpa not psi? 275kpa is like 40psi I think which is lower than mine cold but its still plenty high to keep the engine lubed.
Old Nov 5, 2009 | 12:00 AM
bandidolenny's Avatar
That's fine... You should have at least about 10psi of oil pressure for every 1000 rpm.
Old Nov 5, 2009 | 06:49 AM
blzR's Avatar
Portcqb:
Yes this is a crazy Kpa! I didn't know there were different calibrations between blazers.
Bandidolenny:
Thank you kindly for the reassurance.Having to move engine& etc to change a lousy oil pump is most insane!
Old Nov 5, 2009 | 12:38 PM
rriddle3's Avatar
If you show your 'location' in the 'user profile' questions like these can be answered more quickly.
Old Nov 6, 2009 | 12:13 AM
blzR's Avatar
Will update pronto rriddle3,thx!
jsmz
Lifting Tech
Jan 6, 2010 05:36 PM
urbex
Dec 15, 2009 11:11 PM
fondo
Jul 22, 2009 05:35 PM
XBlazer01
Jun 16, 2009 11:44 AM
02 Vortech
Tires and Wheels
Feb 20, 2006 10:02 PM
