Oil pressure pegged
Oil pressure pegged
Two weeks ago my 95 blazer was haveing a misfire an low power issue. Later that day I noticed my oil pressure broke the gauge. I found out one my spark plug wire poped off an fixing that resolved the misfire. However the oil pressure when starting cold will read 40 an with a lil acceleration jump past 80 the max number. Once she warms up it tends to read normal setting at about 5 for idle an 40 when about 2500 rpm, if you gun it about 3500 then go past 80 again. I been trying to troubleshoot so I can determine what could cause this. The truck runs fine starts fine although I noticed last night the engine remained hot for several hours when my friend trucks were cool. However coolant sensor doesn't seem to show overheating... Anyways I'm confused. I think it could be a oil sending unit but they tend to read 0 when they go bad not go over 80 so I herd. Got 231k miles starting last night lol. If any one has any thought please let me know. Thank you.
Could be a few things:
Faulty oil pressure sending unit, wiring, connectors, dash gauge
Malfunctioning oil pressure relief valve
Blocked internal oil passages
Wrong oil viscosity (not likely since its jumping around)
Best would be to verify with a known good mechanical pressure gauge to determine if its really high pressure or the gauge circuit.
George
George
George
George
I've been dealing with this exact problem for the last year. I'd just replaced the sender a year or so ago with a NAPA unit, so thought something was plugged, or my bypass in the pump was stuck. Couldn't have been the sender.
Anyway, went to change the worn out distributor, so was able to order an A/C Delco sender, and changed it out too. Pressure reads great now.
I had your symptoms. From engine start, it pegged, then a few miles down the road at stop lights it would be normal. But any acceleration and it would peg.
Now it's 70 on start, creeps up to 75 on acceleration. Then drops to 60 on warm up and 50 or so at stop lights.
Good luck
dviles
Good luck
dviles
Good luck
dviles
Good luck
dviles
If you are reluctant to remove the distributor to access the sending unit then about the only thing you can do is access the contacts on the back of the sender and measure the resistance values and see if the output really pegs. You would only isolate the problem as either the sender/actual engine oil pressure vs the wiring, connectors and dash gauge. I don't know the resistance values across the functional range on this sender, maybe someone can help with that. Another option might be to tee into an oil line somewhere with a fitting and a second access point but I have not looked around to see if there is a spot that could work. That would be as much work as the distr I would think. The last option would be to use the adaptor that screws in to the oil filter threads and allows attachment of a second gauge. Something like this:
If you really do have engine oil pressure problems this needs to be addressed because severe engine damage could result. The proper way to do this is the mechanical gauge route to verify.
Maybe someone else has other ideas that I have not thought of.
George
George
https://www.amazon.com/OTC-Tools-721.../dp/B01A8Q4H4A
George
George
Sure sounds like a faulty oil pressure sender to me.....actually a common failure. And yeah getting to it is a PITA.. Has to be on a cold engine. I am not sure the sender can be changed with the distributor in place or not....have never tried on the Blazer. Usually the sender internal oil seal fails, oil gets inside and shorts out....pegs the needle....then the oil drains out with the engine off, start engine again, sender works for a few minutes and then fills with oil...cycle repeats.
Good luck with it.
Good luck with it.
