oil pressure question
Old Feb 21, 2008 | 12:33 PM
zombiewoof's Avatar
zombiewoof is an unknown quantity at this point
Default oil pressure question
Is it normal for an older 4.3 engine with over 200k miles on it to have oil pressure that starts off cold at 60 and when warm, drive at 40 and drop to 30 at idle?
puralator filter and 5w 30 castrol oil.. Thanks in advance of any replies...
Old Feb 21, 2008 | 12:38 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: oil pressure question
thats what mine does and its a 2002, No noises or anything wrong yet..I just kept having problems with water pumps but got that settled finally..
Old Feb 21, 2008 | 03:01 PM
rriddle3's Avatar
Yep, you're safe. The old 'rule of thumb' is 10psi for every 1,000RPM. I believe Chevy says the minimum idle pressure is ~10psi.
Old Feb 21, 2008 | 03:25 PM
kerander's Avatar
kerander is an unknown quantity at this point
Not to threadjack, but mine is similar, except that it starts off about 60 and slowly decreases until when the engine is completely warmed up the pressure is so low that the check gauges light comes on and the oil pressure is reading about 10. I was thinking the pump just needed to be changed, which is kinda pain, but is that not necessarily the case?
Old Feb 21, 2008 | 05:00 PM
WisdomRacing's Avatar
WisdomRacing is an unknown quantity at this point
Be careful...if at idle (1k rpms and below) you canget away with 10psi. If the rpms are anything above 1,000, you're not getting enough oil pressure. While the problem could be the pump, it may also be that the oil is getting too hot. What temperature is your engine running at? What type of oil are you using (ie. 5w 30?)
Old Feb 21, 2008 | 06:33 PM
kerander's Avatar
Ya, it's only at idle. As soon as I get on the gas it jumps up to about 40. The temps are totally normal, and I'm running 5W-30. I read somewhere it could indicate worn bearings [:@]. Any truth to that, do you think?
Old Feb 21, 2008 | 07:01 PM
rriddle3's Avatar
You're playing in the red zone. Put a manual gauge on the oil pressure sending unit connection and see exactly what the pressure is. You need to find out if it's the sender or the oil pump itself going south. Remember, the oil pump does not create pressure, it creates flow. The various restrictions in the oil path are what create the pressure.
Old Feb 21, 2008 | 08:39 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Yup, the pumps only create flow, I love seeing those 'high pressure' pumps!! LOL. Well anyway, I agree with Riddle, put a manual gauge on the motor, and see what the motor really has for pressure. It could be just as simple as a bad sending unit. Good luck.
Old Feb 22, 2008 | 12:30 AM
kerander's Avatar
Will do. Thanks.
LWegner
May 8, 2011 08:25 AM
Spectreblazer
Mar 15, 2010 11:16 PM
davidsv8mustang
Feb 18, 2010 02:29 PM
zippy199
Oct 22, 2009 06:36 PM
Ak95Blazer
Jan 7, 2009 06:56 AM
