one highbeam not working
I have a 1999 GMC jimmy that i put an HID headlight convertion kit on. I did not like it so i took it off after about 5 min. When i put the halogen bulbs back in the driver side highbeam would not work. I changed the bulb checked all the fuses and even changed the DRL relay under the hood and it still wont work. The plug has no power so i checked the wires in the harness about a foot from the plug and still have no power. The passanger side works but the driver side does not. the ground is good the fuses are good and the switch is good but the light wont work
*Moved to 2nd Gen Tech* - As per the section description, the New Member Area is for new member introductions only
Here is the diagnostic chart on your issue: http://i11.photobucket.com/albums/a1...LH_HI_beam.gif And here is the wiring schematic: http://i11.photobucket.com/albums/a1..._Power_sch.gif |
Thanks for the schematic this should help
