one highbeam not working
Old Jan 8, 2010 | 09:29 PM
j80's Avatar
j80
j80 is on a distinguished road
Default one highbeam not working
I have a 1999 GMC jimmy that i put an HID headlight convertion kit on. I did not like it so i took it off after about 5 min. When i put the halogen bulbs back in the driver side highbeam would not work. I changed the bulb checked all the fuses and even changed the DRL relay under the hood and it still wont work. The plug has no power so i checked the wires in the harness about a foot from the plug and still have no power. The passanger side works but the driver side does not. the ground is good the fuses are good and the switch is good but the light wont work
Old Jan 9, 2010 | 07:25 AM
*Moved to 2nd Gen Tech* - As per the section description, the New Member Area is for new member introductions only
Here is the diagnostic chart on your issue:
And here is the wiring schematic:
Old Jan 9, 2010 | 05:01 PM
j80's Avatar
j80
Thanks for the schematic this should help
dusktiger
Oct 9, 2014 11:12 PM
TheDesertFox
Oct 9, 2006 08:14 PM
timetoblaze
Nov 20, 2005 09:52 AM
BlazerChick
Apr 24, 2005 03:14 AM
timetoblaze
Mar 13, 2005 10:09 PM
