Open Diff Out - Limited Slip In
Hey Les....I did not get the backlash exactly the same; I measured 0.0085 on the open-diff. The original configuration was only one cast shim on each side....had to pry the diff out it was so tight.
I tried to use the same shims, but just would not go in, so I reused the right side shim, then put in a stack which gave me a backlash of 0.009...which I thought was good.
According to some info I found, I thought the backlash range was 0.006 - 0.010....but that was for the older style 5-cut ring gear...which I believe I have the 2-cut ring gear so the backlash range is tighter at 0.003 - 0.006. Which makes my original measurement of 0.0085 to be out of spec....makes sense with 167k miles of wear.
Thank you for the bearing numbers.....have found them using those numbers.....
Yeah I found that trying to tap the shim into place with the carrier/races already in place, just does not work. For now I put the open-diff back in; carrier bearings are shipping today, but need to have my Blazer back on the road again. Once I get the new bearings pressed onto the limited-slip diff, then I can try again. Will only cost me a cover gasket....which I forgot to order with the bearings...crap!!
Got it...factory G80....I was remembering the G80 differently for some reason. What ratio is it? Just curious.
3.73...that is what my Blazer has.
tmlittle:...are you asking what is available now or what was available? I think there were three ratios available when new. What is available now, I have not looked, as I was staying with the 3.73.
Yes I was wondering what is available today. I have a a fun healthy LT1 in a 1st gen connected to a 700r4 trans that has a healthy overdrive. So for fun at the strip I wanted to know if a 4.10 existed
4cyl 5speed OD S10 should be 4.10:1
After going through my unsuccessful diff change-out, I really got to thinking about why in the world would GM/Chevrolet EVER sell a 4wd Blazer with an open-diff....why? Why was the G80 not a required option in all 4wd Blazers? So guys help me understand this. Yes I know an open-diff is cheaper...but really, is this the reason?
Now since I have never driven my Blazer in snow....does having two open-diffs, when in 4wd, work in snow or loose sand?
Will rear tire scuffing be a problem when I get the limited slip installed?
