Open Vacuum Line
Old Jul 28, 2012 | 12:34 PM
garry2000blazer's Avatar
garry2000blazer is an unknown quantity at this point
Default Open Vacuum Line
I had to replace the short piece of vacuum line by the master cylinder at the tee that goes down to the line into the vacuum reservoir. My problem is I didn't notice if the line going off to the right was plugged into anything. It doesn't look like it was, and I can't find any ports it could have come off of. Is it just a vent or something? Thanks
Old Jul 28, 2012 | 02:05 PM
mychevyisntheavy's Avatar
mychevyisntheavy is on a distinguished road
it either goes to the vacum ball that should be there or to the transfer case
Old Jul 28, 2012 | 02:16 PM
Rottidog's Avatar
Do your vents work? It may go to the vacuum canister if the fenderwell & from there they run to the HVAC controls. At least on my '02 that's where the vacuum canister/ball is.
Old Jul 28, 2012 | 04:07 PM
Thanks guys. I finally found it. There's a nipple molded into the plastic panel (part of the vacuum canister?) under the ABS controller but it's recessed so the end of the nipple is flush with the panel. I would have never found it without loosening the ABS controller so I could nudge it out of the way a little. Even then I needed to use my inspection mirror to make sure what I thought I was feeling was the port.
Old Jul 28, 2012 | 04:36 PM
Well, test drive tells me either that wasn't the right place or I have another leak somewhere. What started this was my service 4WD light would come on and I noticed it always seemed to do it when I moved the accelerator pedal, so I assumed it was vacuum related.
I have the NVG236 xfer case (RPO NP8) and I have replaced the actuator under the battery.
The vents take about 20 seconds to respond to a change.
Is there vacuum going to the NVG236 transfer case or is it completely electronic?
Old Jul 28, 2012 | 05:07 PM
Maurer6156's Avatar
Maurer6156 will become famous soon enough
The vacuum line sounds like it is exactly where it is supposed to be. I had a problem with my 4wd not engaging and it was because that exact piece of hose wasn't connected to the little vacuum "ball" (not actually a ball i don't believe) in the fender
Old Jul 28, 2012 | 05:40 PM
on my truck a vacum line runs under the battery tray to pull it in four wheel drive. so make sure the line is hooked up rite
Old Jul 28, 2012 | 06:08 PM
Thanks Maurer...at least I know I got rid of one variable.
I made sure all of that was good when I replaced the actuator...thx
bruce_w
Oct 27, 2024 04:16 PM
chris015
Feb 14, 2012 10:20 AM
Bberry20
Oct 27, 2009 02:44 PM
chris015
May 21, 2009 01:17 PM
1996BZR
Jun 2, 2006 08:56 PM
