Opening back hatch from inside??
Old Jul 12, 2011 | 01:28 PM
trailblazr81's Avatar
trailblazr81 is an unknown quantity at this point
Default Opening back hatch from inside??
Can someone tell me on say a 96-00 year 4 door Blazer is it possible to open the back hatch from the inside? Im thinking of getting one and using it to camp/sleep in and would like to be able to open the back hatch and not always crawl in/out through the back seat door. Is there a quick n easy mod maybe to do this?
Old Jul 12, 2011 | 01:38 PM
jackets84's Avatar
jackets84 is on a distinguished road
there should be a button on the dash board that under where the 4x4 selector would be that says rear hatch you hit the button and should hear a click in the rear this means you can open the hatch even without getting out mines a 2001 but it should be the same
Old Jul 12, 2011 | 02:27 PM
Sweet!!
Old Jul 12, 2011 | 03:25 PM
bigzimnh1's Avatar
bigzimnh1 is on a distinguished road
Mine is a 97 and the hatch button is right next the headlight switch.
Old Jul 12, 2011 | 06:35 PM
Awesome. Thanks.
Old Jul 12, 2011 | 06:50 PM
Benedict1337's Avatar
if you have a keyless entry there should be a button on there too
Old Jul 13, 2011 | 01:59 PM
cdw78's Avatar
cdw78 is on a distinguished road
for some reason can't open mine with the push button or from the rear of the truck, any ideas what could be causing this?
Old Jul 13, 2011 | 02:04 PM
fuse may have went bad. I had a similar problem my motor was working but when I took it apart the little arm on it to unlatch the gate was broken (made of plastic). I used a little screw in metal hook in what was left of the plastic has been working good ever since
Old Mar 25, 2013 | 05:33 PM
greg101's Avatar
greg101 is on a distinguished road
1997 blazer dash button doesn't work ,nor does button on tailgatewhat is the magic word to open so I can see whats wrong #@@##}|||???&^^^%$thanks for tour time
Old Mar 25, 2013 | 10:58 PM
LeWhite's Avatar
Uh Ooo. Carefully pull back the interior panel near the center mound. About three sixteenth is enough. Get a long allen wrench and push down on the latch in front of the window loop. Drop the tailgate; remove the whole panel and look for a loose wire or a broke actuator arm (i think its blue) Good luck.
