out of things to replace
Old Mar 17, 2013 | 07:43 AM
puzzled's Avatar
puzzled is an unknown quantity at this point
Default out of things to replace
2001 blazer 4dr 2wd runs fine in park drop in drive and give gas and it struggles to go and miss fires . i hav replaced spider, coil, plugs,wires mass air sencor ,modual tps, and nothing seems to make it better any ideas
Old Mar 17, 2013 | 08:56 AM
rexazz2's Avatar
plugged cat.??
when it happened to my sister Monte Carlo SS it sounded muffled at the tail pipe
Old Mar 17, 2013 | 09:19 AM
cleburne red's Avatar
Any codes? Check engine light? Sounds like a MAP sensor, but I'm not sure if they still had them by 2001.
Old Mar 17, 2013 | 10:16 AM
puzzled's Avatar
took y pipe off still does it
Old Mar 17, 2013 | 11:49 AM
puzzled's Avatar
Thumbs down
just went out and replaced distributor still the same
Old Mar 17, 2013 | 02:02 PM
Have you checked fuel pressure and leakdown? Fast, easy and free to check it.
Old Mar 17, 2013 | 02:05 PM
puzzled's Avatar
i have checked fuel presure and leak down
Old Mar 17, 2013 | 02:29 PM
What was the regulated pressure, (key on, engine off, fuel pump activated) and what was the pressure 10 minutes after the pump was deactivated?
Old Mar 17, 2013 | 03:12 PM
puzzled's Avatar
54 psi
Old Mar 17, 2013 | 03:13 PM
Is that regulated or after 10 minutes? (check post #8 again)
