out of things to replace
Old Mar 17, 2013 | 03:58 PM
cleburne red's Avatar
It's like pulling teeth!
Old Mar 17, 2013 | 04:02 PM
puzzled's Avatar
puzzled is an unknown quantity at this point
regulated 54 and only drops to 50 after 10 minutes
if u give it gas it jumps to 60
Old Mar 17, 2013 | 04:06 PM
Back to post #8.... What is the pressure with the ignition ON, engine OFF, and fuel pump running? Then, what is the pressure 10 minutes after the pump shuts off? GM does not publish any "engine running" specs, all fuel pressure readings are taken with the engine off.
Old Mar 17, 2013 | 04:14 PM
puzzled's Avatar
ill get back to u gunna go get tester again
Old Mar 17, 2013 | 05:55 PM
puzzled's Avatar
ok key on pump running 62psi key off after 10 minutes 42 psi
Old Mar 17, 2013 | 06:29 PM
Now we're gettin' somewhere! Pressure is acceptable but leakdown is excessive. Next step is figure out what's leaking. Provided there are no external leaks, the leakdown problem could be in the tank, or in the plenum. To determine which one requires modification of the fuel pressure tester so it will connect directly to the outlet of the fuel filter. This will require some "creative plumbing" on your part. If you're not comfortable with this, take it to a shop that has the equipment and a competent technician.
Old Mar 17, 2013 | 06:55 PM
puzzled's Avatar
the fuel filter holds 56 psi for ten minutes
Old Mar 17, 2013 | 07:03 PM
Perfect! What was the pressure when the pump was running?
Old Mar 17, 2013 | 07:06 PM
puzzled's Avatar
62 psi
Old Mar 17, 2013 | 07:14 PM
Should be 73psi to 108psi. Was the tester connected to the filter so all fuel pressure and flow ended at the tester? If not, it's indicating an inconsistency in leakdown from your other test, which is neither here nor there at this point.
EDIT: Bottom line what we're doing is isolating the pump from the plenum and checking maximum pump output pressure and leakdown in the tank.
