out of things to replace
Old Mar 18, 2013 | 08:48 PM
  #31
puzzled's Avatar
puzzled is an unknown quantity at this point
p0101 first then p0300 then o2 senser that came up because on the first day i cut the pipe infront uf the cat that has not come back on since i weld it back to gether tonite
Old Mar 18, 2013 | 09:06 PM
  #32
Did you clear the codes and drive it after welding the pipe?
Old Mar 18, 2013 | 09:09 PM
  #33
puzzled's Avatar
yes codes were cleared
Old Mar 18, 2013 | 09:13 PM
  #34
ok. Does your scan tool allow you to view fuel trim? Should be a menu showing "Short term fuel trim" and "Long term fuel trim" or possibly STFTB1, STFTB2, LTFTB1 & LTFTB2.
Old Mar 19, 2013 | 04:23 PM
  #35
puzzled's Avatar
no this one does not
Old Mar 19, 2013 | 04:29 PM
  #36
P0101 is a mass air flow sensor or circuit problem. Any chance you have a K&N air filter on it? If so, the oil on the filter may have contaminated the elements in the MAF sensor. Whether you do or don't have a K&N filter, remove the sensor and clean the elements with brake clean spray, (it leaves no residue). Be very careful not to disturb the elements, they are very fragile.
Old Mar 19, 2013 | 04:43 PM
  #37
puzzled's Avatar
i see on here people talking about spark plugs when i changed my plugs they were out of ac delcos so they gave me bocsh
and no k&n filter
Old Mar 19, 2013 | 04:53 PM
  #38
puzzled's Avatar
going to the parts store to get correct plugs and brake cleaner
Old Mar 19, 2013 | 04:58 PM
  #39
AC Delco 41-993 with a gap of .060"
Old Mar 20, 2013 | 03:00 PM
  #40
puzzled's Avatar
Pulled plugs to replace and cylinders 1 3 5 hav e oil on them
