overheating in az
Old Jun 10, 2010 | 10:35 AM
bbogue4's Avatar
bbogue4 is on a distinguished road
Default overheating in az
I have a 1999 chevy blazer v6 overheating badly.I put a new radiator,clutch fan,thermostat,hoses and water pump.I am up in arms cuz it still overheats.My local shop has checked for head gasket issuies and have ruled this out ,there is not any oil in the coolant and the radiator cap is new as well.The only thing we have not done is burp the system.
Is there anything you guys can think of besides putting an electric fan in front of the radiator?
Old Jun 10, 2010 | 11:58 AM
rriddle3's Avatar
Originally Posted by bbogue4
...The only thing we have not done is burp the system...
That's the thing you need to do now.
Old Jun 10, 2010 | 01:26 PM
bbogue4's Avatar
Just purged and still got up to 260 deg's
Old Jun 10, 2010 | 02:30 PM
84BlazerS10's Avatar
Does the parts you got work right? Also does you radiator fan kick on while the car is running?
Old Jun 10, 2010 | 03:56 PM
bbogue4's Avatar
Yes,and yes.At idle it's fine ,but when you are driving it starts to heat up.
Old Jun 11, 2010 | 01:47 AM
onishogun's Avatar
onishogun is on a distinguished road
check for intake manifold leak
Old Jun 11, 2010 | 10:21 AM
bbogue4's Avatar
Angry
That can make it run hot?wouldn't it leak somewhere?
We took it back to the shop that put the water pump on and they think its a head gasket leak ,but they dye checked it twice and said head gasket is fine
Old Jun 11, 2010 | 11:38 AM
jigger's Avatar
jigger is on a distinguished road
Is the system building up high pressure. My 95 was and turned out to be a cracked head. Fixed the heads and cool as can be now.
Is your timing advancing as it should at higher RPM's?
Old Jul 1, 2010 | 04:35 PM
bbogue4's Avatar
Ok,new stant 16lb cap,flushed 3 times ,burped the radiator ,new rad,new water pump and thermostat.I even put 2 12'' electric fans that come on at 180 deg and I am still over heating.
Can anyone help!!!!!!!!
Old Jul 1, 2010 | 11:36 PM
rriddle3's Avatar
Haas anybody verified the operation of the engine coolant temperature (ECT) sensor?
