Overheating question
Old Dec 7, 2013 | 10:44 PM
C210M's Avatar
C210M is on a distinguished road
Default Overheating question
2004 Blazer 4 door 4WD. I am having an overheating situation. When driving on the highway mostly when the temperature is 85 or higher I noticed that the temp gauge runs a line or two over the mid point. After slowing down and while driving slowly in a parking lot the temp continued to rise to 3/4 and then boiled over. I had added regular coolant and then discovered the coolant in the cooling system turned to a muddy looking solution. i had the cooling system flushed and the shop told me the coolant was still cloudy after flushing several times. I have replaced the thermostat and radiator cap but the same situation continues to occur. I have experimented with having the air conditioning on and off. There is definitely an improvement when the air conditioning is off. It seems like the temp will come down and not cause a overheat or boil over with the air conditioning off. I think it is time for a new radiator. Could there be anything else to consider before radiator replacement? Fan clutch or water pump? Any suggestions or similar experience would be appreciated. Thank you
Old Dec 8, 2013 | 09:09 AM
dobyken's Avatar
dobyken is on a distinguished road
Most likely the radiator is plugged with crud which might require replacement. There's a complicated procedure for doing a chemical flush but it doesn't work all the time. Mixing regular antifreeze with the orange dexcool turns to sludge.
Old Dec 8, 2013 | 09:18 AM
rriddle3's Avatar
Make sure the engine fan is operating correctly.
NOs
Jan 22, 2010 12:47 PM
cmh_20
Nov 21, 2009 11:39 AM
XTREME POS
Dec 26, 2007 08:18 PM
vagnozzi
Sep 10, 2007 05:09 AM
sectshun8
Feb 27, 2006 01:54 PM
