p0137 Now!
p0137 Now!
Got a P0137 code yesterday. I did a little reading up on old threads and learned that its related to heated oxygen sensor on B1S2. Being this a model with 3 sensors 98+. It would make it the sensor after the cat. I erased the code and will wait and see if it comes back. Meanwhile I am looking at a replacement. What do you guys prefer brand wise, I cant seem to locate a GM part. And I dont know if Denso or AC delco is the actual OEM manufacture. I see Bosh as another option.
Are you able to graph the 3 O2 sensors so we can see what that post cat guy is doing relative to the other 2?
I would get the Delphi or GM version at Rock Auto.
George
George
Just keep in mind that that error code says you have a circuit problem not necessarily an O2 sensor problem. It’s your call as to whether you want to replace the sensor before doing some diagnostics to rule out power, wiring, the cat or other causes of the problem.
George
George
ok, so I was not able to get in-depth readings on the sensor. I only got basic voltage reading graph. I noticed the sensor seemed to be off or dropping out time to time. Could this be what's tripping the code. I went ahead and deleted the codes and 90 miles later not code re-appear. Will continue monitoring check engine.
