P0152 after car wash
Hello all, I keep getting a p0152 after going to the car wash. Particularly after rinsing front wheel wells.
I thought originally that the spark plug wires were shot, but I have done a complete ac delco tune up and it still happens. I also feel a light rough / idle issue when I’m in park still. The plugs , wires, coil, icm are all replaced.
After the wash, the car runs really rough and pops for a minute or two. What should I check? I thought the 0152 was from a misfire, but I have no other codes. I’m completely stumped.
P0152 means that the Bank 2 Sensor 1 (pass side, pre cat) Oxygen sensor circuit is seeing anout of bounds voltage condition, in particular the voltage is too high for too long. This can be due to many things:
George
- The O2 sensor is bad
- The wiring in that circuit is bad
- There is a short to power on the signal wire
- The ECM is bad
- The computer has lost fuel control from bad injectors, wiring, power, ground, etc
George
Thanks George, wiring is probably the culprit, the plug seems to be right on the frame rail there near the wheel well. I just tugged on it slightly and inside the loom was full of water.
I think all of the sensors are original to the tune of 132k on my 2000 LS, afraid to pull one and switch it, will they come out easy?
im in Buffalo, salt and rust and harsh.
I am betting on wiring or connector. Yes the sensor can be tough coming out. You will need an O2 sensor wrench, possibly some PB Blaster and if really bad, some heat. There are a couple of wrench styles but here is one option:
That said, you can start with the other steps and leave the sensors alone for now.
George
George
BlackBeauty43
Nov 20, 2013 07:57 PM
PseudoKirby
21
May 4, 2012 10:30 PM
ExplicitYourSelf
14
Jun 7, 2010 06:25 PM
