p0154
Old Feb 4, 2024 | 02:41 PM
crossspencer's Avatar
crossspencer is on a distinguished road
Default p0154
I have a 2000 chevy blazer, having troubles after i replaced the B2S1 and now i have a p0154 code. I have tested continuity from the connector to the vcm and everything is good. When i had the key on but engine not running it was running at 477 mv. Not really sure if its a bad ground or not. Please helpppp
Old Feb 4, 2024 | 08:48 PM
GeorgeLG's Avatar
Do you have a scanner that can graph the o2 sensor signal?
George
Old Feb 4, 2024 | 08:53 PM
Default GeorgeLG
i only have a bluetooth autel scanner that shows the mV
Old Feb 4, 2024 | 09:03 PM
GeorgeLG's Avatar
Graphing is best but since you do not have that ability can you watch the O2 sensor voltages and see if they switch up and down and if so to what voltage levels?
George
Old Feb 4, 2024 | 11:47 PM
it stays at 447 mV constant even with key on but engine not running and while driving it
Old Feb 4, 2024 | 11:52 PM
GeorgeLG's Avatar
Measured between what two points?
George
Old Feb 4, 2024 | 11:54 PM
sorry a little confused on what you're asking?
Old Feb 4, 2024 | 11:55 PM
GeorgeLG's Avatar
Where did you place the two meter probes?
George
Old Feb 4, 2024 | 11:57 PM
Oh. I just watched it on my scanner app didn't even think to check voltage at the plug if so what two points should i test
Old Feb 5, 2024 | 12:00 AM
by the way im 19 dont know alot but i know the basics and then some so im trying to do it myself instead of paying someone else to do it
