p0171-174
Old Mar 1, 2012 | 04:31 PM
rod45's Avatar
rod45 is on a distinguished road
Default p0171-174
Just replaced tank and fuel pump to fix a leak and trouble code for fuel tank pressure sensor on my '02 2dr 4X4 Blazer. After start up it missed and threw code for miss fire. We found we had 80 psi of fuel pressure. After we replaced the pressure regulator it runs fine except it gives me codes P0171 and P0174 which is a lean condition. I have check vacuum hoses and found nothing. What could we have done to cause these codes? HELP!!!!
Old Mar 1, 2012 | 04:40 PM
pettyfog's Avatar
What you did was reduce the pressure from 80 to 60. The poor wittle 'puter is confused. It tried to cope with higher pressure and shortened injector cycle.. now it has to adjust fuel trim back to longer cycles.
Disconnect battery cable for an hour or so, or overnight.. think that still works.
Old Mar 6, 2012 | 06:19 PM
rod45's Avatar
Disconnected the battery for about 4 hours. I was surprised to see the codes were still in there when I hooked it back up. I cleared the codes and made a couple trips with it and the MIL came back on but this time only the P0171 and P0171 pd codes showed up. I'm hoping that I'm gaining on it. I cleared the codes and put some Sea Foam in the tank to clean things up a bit. If that doesn't do it I'll disconnect the battery for a couple days and try it again. Thanks for the info.
Disconnected battery for 4 days, I don't think it did a thing. Still have same problem. Any ideas, anyone?
Old Mar 14, 2012 | 03:36 PM
pettyfog's Avatar
How's it running? If it's hesitant on throttle up and jerky, try disconnecting MAF connector after warm up. If it drives better, clean the MAF
Old Mar 15, 2012 | 08:25 AM
rod45's Avatar
Had battery disconnected for 4 days (I'm not sure this works now) and nothing changed. I did see on another thread where someone said something about the air box or duct on top of the throttle body might suck air where it meets the T/B. I sealed that area and am waiting to see what happens. It runs perfect, doesn't feel lean at all, just throws codes.
Old Mar 15, 2012 | 08:47 AM
pettyfog's Avatar
What is the idle rpm, warm? It should be 650 plus or minus 25, if it's higher than that, it's a vacuum leak on the engine side of throttle plate.
Test: Warm engine. Take off inlet tube at throttle plate, loosen IAC, slide thin feeler gauge over outer IAC port {filter side} and snug the iac bolts. If it then idles at 650 or more, you either have a vac leak or someone screwed with the throttle stop screw. Adjusting that screw is a last resort and will not affect the fuel air mix. The reason is that the IAC has to have a working range so the rpm with iac closed should be below 600.
But really.. whether or not have a vac leak, Just clean the MAF. And make sure all clamps between MAF and throttle body are tight. It's part of good maintenance, anyway.
Old Mar 15, 2012 | 05:13 PM
rod45's Avatar
It runs great. Idle is about 600 rpm and steady. No lean hesitation or roughness at all. If it wasn't for the codes showing up, I never know anything was wrong. Is it possible that the fuel filter could be bad and still show good pressure but loose volume? Sealing the air box didn't help at all. Took it for a short drive to warm it up and shut it off for a few minutes. Started it back up and within about a mile or two the MIL comes on with 171 & 174 showing up along with 171 & 174 pd. I will try cleaning the MAF also. I just don't understand how changing the tank, fuel pump, and pressure regulator could cause all this. I've got to get it E-checked in May and want it to be right.
Thanks again,
As far as being old, I'm only a couple years behind you.
OK, cleaned the MAF and replaced fuel filter, had absolutely no effect. What is left? I am thinking about TNT. Found MAP a little loose feeling. Removed it and used a small amount of silicone to seal it in hole. Today I tested it and it ran fine. First trip about a half hour and showed no codes. Second trip about half hour and no codes. Third trip in ten minutes MIL came on. Drove homeand checked codes. Had P0171, 174, 171pd, 174pd and P0137. It was also showing a tendency to run a little hotter than normal. I have cleaned the radiator and condenser so I know that's not the problem. It didn't start to get warmer until the MIL came on.
Last edited by rod45; Mar 21, 2012 at 08:22 PM. Reason: Adding info. Is anybody out there.
Old Mar 22, 2012 | 10:12 AM
pettyfog's Avatar
Well... this sorta stumps. because the only driveability issue you show is tendency to overheat, which too-lean does.
Check your ECT and IAT against this
Check MAP scan against manifold vac reading. Man vac should show 17-22 inhg. you may have to convert what MAP says.. remember it registers ABSOLUTE pressure so it's reading will reflect above pure vacuum.
Old Mar 22, 2012 | 11:57 AM
rod45's Avatar
Is there anything he could have done changing the pressure regulator that could cause this problem?
Thanks again.
Old Mar 22, 2012 | 12:06 PM
pettyfog's Avatar
If your FP now reads correct, I cant think of anything that would result in a perpetual lean.
Suggest you read your plugs. I imagine all would also indicate lean.
Longshot is that all or most injectors are crudded up.
If you're thinkking of upgrading to MPFI, now's good a time as any
Check those things above, first.
