P0200 and P0300
Old Mar 6, 2014 | 07:02 AM
Ummmwhat's Avatar
Ummmwhat is on a distinguished road
Default P0200 and P0300
Hi guys. Hoping you can help me. Bought my 2001 Chevy Blazer at an auction, have replaced the idler arm, pitman arm, radiator, ABS control module and lower intake manifold gasket so far. I left work last night and noticed she was idling rough, and SES light starts blinking. I had a Bluetooth scanner in my glove box, pulled a P0200 and a P0300 after I drove home.
Really trying to avoid the mechanic, my wallet is still kind of sore. What diagnosing steps should I take?
Old Mar 6, 2014 | 08:10 AM
canuck blazer's Avatar
canuck blazer is on a distinguished road
Well the po300 is random miss fire so I would look at plugs and wires possibly cap and rotor as well that may be whats throwing both codes, But only use AC Delco parts as these vehicles Do NOT like after market parts
Old Mar 6, 2014 | 10:10 PM
justaguywithtools's Avatar
justaguywithtools is on a distinguished road
the p0200 code is an injector circuit malfunction code. the p0300 (random/multiple missfire) is the result of the injector issue and may not be a problem in itself. an open or shorted injector, wiring problem at the connector on the manifold, or an ecm issue can all be the culprits. if you can get your hands on a non contact thermometer (pyrometer) you can check the exhaust manifold ports to find which cylinder is cold (the missfire cylinder) and greatly narrow down the wiring to check.
Old Mar 9, 2014 | 10:19 PM
Ummmwhat's Avatar
So I replaced the cap and rotor, cleared the codes, and ran it for a few miles. Everything was good, codes didn't come back. Just went out to start it after it sitting about 8 hours, and it's acting up again but the SES light hasn't came on yet. Going to do plugs, wires, and fuel filter tomorrow.
Old Mar 9, 2014 | 10:22 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
Here save yourself some trouble & possible wasted money!!!! Do a fuel pressure leak down test trust me on this...any amount of research here will tell u the spider assy on these trks are junk
Old Mar 9, 2014 | 11:24 PM
Ummmwhat's Avatar
So, it's cylinder 1 that is misfiring now according to the scan. (Yes, I scan codes wayy too much). Narrowing it down
I may try a leak down test tomorrow.
mebob2001
Aug 11, 2014 10:32 AM
princered72
Mar 11, 2012 09:11 PM
DrEaMsTeVe
18
Mar 16, 2010 12:48 PM
98blazr
44
Aug 21, 2009 01:17 AM
berniescout
Jan 20, 2007 12:42 AM
