P0300 Code 4.3L vortex Engine
Just wanted to let everybody out there know that I found my problem with my P0300 code. Like I said I just got it back from son and this was the first weekend I had to look at it . I decided to put a cam sensor in it since every thing else was changed and I said well I would put a new cap and rotor on it while I was there. I pulled the cap and started to pull the rotor and I noticed some thing funny with the rotor it did not feel right when I went to loosen it up so I grabbed the rotor and pulled up on it and noticed that the upper shaft of the disturber would move back and forth. Yes sir the distributor was garbage,I had one in my garage put it in and it runs perfectly now. Now I can see why it sets the P0300 code because the rotor is moving all around under distributor hitting and missing the terminals on the distributor.
some buddy help!!! ive been fighting this random multiple misfre. its really bad and ive done evrything. there is one thing i had my ignition switch go bad so i got a whole colum out of a 97 jimmy mine is a 98 the switches are diff would that be a possible solution that because its a difff switch it could be causing it to throw that code. its always throwin random codes that i fix and they do nothing please help its a money whole an need to fix it fast.
palmer96
Jul 16, 2013 08:40 PM
98blazr
44
Aug 21, 2009 01:17 AM
