P0300 Flashing CEL '01 Blazer LS
Old Feb 10, 2011 | 05:36 PM
joey's Avatar
joey is an unknown quantity at this point
Is PO300 active when the engine is in open loop mode? I had a nasty PO300 that caused all kinds of misfires EXCEPT when the engine was in open loop mode. Then as the engine warmed and transitioned into closed loop mode the code suddenly became active. The problem turned out to be a corroded O2 sensor connector on the left bank. Cleaned the harness connector, replaced the O2 sensor, and applied dielectric grease to the terminals and the code when away. Truck has never ran better!
98 Blazer 4wd
Old Feb 21, 2011 | 10:19 AM
Blaze01's Avatar
Blaze01 is on a distinguished road
Hi. Got two new ac delco O2 sensors..... and same thing.... flashing cel. Cylinder one and four now misfiring equally / at same rate. So then I installed a new distributor......NO more misfire....YAY................BUT now getting a po341 code. So im guessing I need a case relearn....but before; do I need replace the Crank Sensor under the front of the engine? Thanks? More infor on code po341 will be helpful. Thanks again.
Old Feb 21, 2011 | 10:22 AM
blazinloud's Avatar
just a guess, but did you try disconnecting the battery for a while?
Old Feb 21, 2011 | 10:29 AM
Blaze01's Avatar
hi blazinloud..... the negative cable was unhooked before and after installing distributor. Clear codes with scanner....been at work since after, will go out there and check it out today. Sure happy i can now install my cat.
Old Mar 2, 2011 | 03:54 AM
Blaze01's Avatar
Ok problem solved. I install two faulty cam sensors, replaced this time with genuine acdelco and put in a new cranksenor then took it from a case relearn at a gm dealer... They did it for free! (I went in expecting to pay 120 for the relearn and so should you.) First aftermarket sensor made cel flash at 2500 rpm with huge missfies on 1 & 4 equally.... Second aftermarket cam sensor no misfire, but code po341.
Old Mar 2, 2011 | 06:47 AM
Glad you got the problem solved! I try to always steer people towards AC Delco sensors and ignition components. Their quality control seems to be quite a bit better than other aftermarket suppliers. It is unfortunate that you had to find out the way you did though.
Old Mar 5, 2011 | 10:22 PM
jpalen's Avatar
jpalen is on a distinguished road
With a P0300 and P0301 and P0304 check your spider for leaks. Pull the top half of the intake, then reconnect your fuel lines to the spider, plug it in and turn the key to ON and look for fuel leaks from the lines or the regulator. If the regulator leaks it dumps fuel directly into the runners and fouls plugs. I just did mine today. Replaced the regulator which was leaking and now runs great again.
shleprock
Dec 29, 2014 05:50 PM
cory30189
22
Aug 17, 2012 02:16 PM
BipolarExpress
Jul 24, 2012 08:45 PM
tibby
May 27, 2012 10:42 PM
schollianmj
Nov 18, 2011 04:46 PM
