P0300 Freeze frame data
Old Dec 17, 2011 | 05:45 PM
keeslinger31's Avatar
keeslinger31 is on a distinguished road
Default P0300 Freeze frame data
I cannot wrap my head around this problem. When i bought the truck it ran great had power and would even squeal the tires with ease, then it started with the p0300. That was 5 months ago fast forward to now ive replaced
Cap
Rotor
Plugs
Wires are good, have a new set to try anyway but they are all the same ohm
Replaced spider with the updated one.
Tried coil
doesnt burn coolant or have a vacuum leak
cleaned egr also watched it on the ethos seems to work
Here is some freeze frames
Why are my short term trims so bad? I know its misfiring But why?
and some scopes of the o2's i think they may be next. Is this right?
Another couple pics of it at idle
The misfire chart, Its random
another freeze frame
Is the cam retard supposed to be -7?
Finally the truck in question,
Please any help i have more but i think what i have should help. I think im missing something obvious
Last edited by TripleBlackBlazer; Dec 17, 2011 at 08:31 PM. Reason: Merging consecutive posts-Please use the 'Edit' feature to add more info to your last post if no one has replied
Old Dec 17, 2011 | 08:34 PM
TripleBlackBlazer's Avatar
Nice looking truck and I see you have some data to help. Welcome to the forum BTW.
This forum (and the people that contribute to it) is great. We have a diagnostic section that explains a lot of the codes that we get in these trucks. Unfortunately, P0300 is one of the hardest to track down. So many people have so many different experiences. Fortunately, most of them are documented on here.
Please search for P0300 and you should find more information than you care to read. I actually just had a small bout with P0300 after an intake manifold gasket repair. Turns out #2 and #5 cylinders were not getting fuel because the poppet valves in the spider were stuck closed.
Old Dec 18, 2011 | 02:43 PM
Ive already exhausted every resource I can find by using google and multiple forum searches. Most end with injectors or the ignition system and seeing as ive replaced those they dont help at all. So ive posted the freeze frame data as to directly pinpoint the problem But nothing stands out to me besides the st trims and the cam retard which im working on right now.
Is the distributor a tooth off? Am i to pull it and rotated counter clockwise for more advanced or the other way? Long night lol
Old Dec 18, 2011 | 05:56 PM
Have you done a compression check? Cylinder leak down test? Tested fuel pressure during operation while monitoring misfire count on the scan tool to see if fuel pressure drops out?
Maybe you should go through each and every test that you have done and the results for us. The P0300 code in the DTC section also links to another thread that runs through A LOT of different scenarios. It's a long read, but can be informative if you've already exhausted all other avenues.
Old Dec 21, 2011 | 08:15 PM
I did a compression test on cylinders 1 and 4 since they misfire the most. I tested the fuel pressure earlier tonight was 55-60 at idle and would raise as i accelerated. Ive noticed a few noises since i bought a new gates belt. Now i can hear something on the drivers side of the motor maybe that sounds like air is rushing through? It seems to affect the idle alot. But its most noticeable when the engine bogs after revving, it seems to hesitate when revving in nuetral.
New parts list
Cap
Rotor
Plugs
coil
Verified spark
Fuel filter
Updated mfi injectors
Verified fuel pressure at idle revving and under load driving and leakdown didn't budge (new regulator and injectors in kit)
Cleaned egr and verified function with scantool
Cleaned contacts on every plug i could find
Cleaned maf Its new looking and works on the scantool
I messed with the distributor and checked the gear and set cam retard as close to 0 possible. Was -7 now its -4
Ive checked for vacuum leaks at least a dozen times. Used up a couple cans of anything flammable
It seems that it doesn't missfire as bad when cold but ive tried a coil
Im thinking Plug wires have a set ready to put on or
ICM?
ECU?
Sometimes the airbag light turns on but if i hit the horn goes off? Unrelated?
I Just dont get it. I want to v8 swap this thing but id hate for it to come back and haunt me if its the wiring or ecu or something I just need to fix it
Getting terrible gas mileage runs **** poor has no ***** i feel someone has tampered with it before to try and fix it.
ANY more help
Old Dec 21, 2011 | 08:32 PM
Mike98Blazer's Avatar
Have you checked distributor shaft play? I've heard some came through with chinese bearings that like to fail and cause a hard to find P0300.
Old Dec 21, 2011 | 09:12 PM
It hardly moves side to side
Old Dec 22, 2011 | 12:31 AM
Gale's Avatar
Gale is an unknown quantity at this point
How many miles and what are the results of your compression test of all four cylinders?
Old Dec 22, 2011 | 06:52 AM
You mean all six I assume.
Old Dec 22, 2011 | 07:23 AM
war00's Avatar
war00 is on a distinguished road
after veiwing this thread and seeing what you have done to your vehicle and the data you have provided us, to me it seems your b1-s1 o2 is reading lazy. first i would check to make sure you dont have an exhaust leak at the manifold or donut @ downpipe as these would cause a lean condition. if that checks out ok i would be thinking about replacing both o2s as they recommend to change them around 100k. couple ways to check since you got a scanner with live data reading would be watch the o2 output while idle and rev it up abit 2500rpm taking note of the sensors. should be sharpe up/down. than introduce a vacuum leak by taking off a line and taking note again at idle and fast idle should be reading high. also i would be checking fuel pressure as well just to make sure. hope this helps
