P0300 on hills and above 2000 rpm
Old Apr 9, 2022 | 11:26 PM
joseywales's Avatar
joseywales is on a distinguished road
Thanks i really appreciate your help on this i will get back with some numbers here asap , now woth regard to a faulty o2 sensor , i did disconnect them all somas to run in open loop and their was no change , or maybe thats not the right way to go about it or does this also rule out an o2 sensor ?
hopefully i will have more info after the weekend , weather looks nasty .
Old Apr 9, 2022 | 11:59 PM
GeorgeLG's Avatar
When you unplug the O2 sensors the truck goes back to open loop and fuel is controlled by the other relevant sensors - MAF, MAP, ECT, TPS, ... In this scenario fuel trims have no meaning but if the truck runs the same under a load then yes that reduces the likelyhood of this being an O2 sensor problem but does not eliminate that possibility if the PCM did not like the input in the first place. Do both banks go into closed loop and stay closed after the truck warms up?
George
Old Apr 10, 2022 | 12:07 AM
joseywales's Avatar
Yes both banks go into closed loop and stay closed .
Old Apr 10, 2022 | 01:46 AM
joseywales's Avatar
This also happens at the same time the p0300 issues but i have changed the maf with no improvement . notice that bank 1 in this scenario is lean and bank2 is barely rich complete opposite , ecm maybe ?
Old Apr 10, 2022 | 08:57 AM
GeorgeLG's Avatar
That MAF sensor code brings up other possibilities.
Check the air intake from filter to throttle body looking for leaks. Replace the or filter is due. Check the quality of the power and ground to the sensor. We may need to check the quality of the sensor wire from the sensor to the ECM.
Another issue is now in play, excessive back pressure in the exhaust. You can either measure back pressure at an O2 sensor port or pull a sensor and go for a test ride.
Lastly we better check all the other sensors in live data to make sure that they make sense. ECT, TPS, MAP/BARO, IAT.
Sure the ECM is always a possibility but that is not the most likely.
Old Apr 10, 2022 | 10:09 AM
perumotors1369's Avatar
perumotors1369 is on a distinguished road
Wonder if one (or both) of the front most O2 sensor(s) are pulled..and then drive with one or both out, if it will be better? Cat thought....
Old Apr 10, 2022 | 11:21 AM
GeorgeLG's Avatar
If your acceleration improves with O2 sensors removed you may have excessive back pressure. It’s a shade tree mechanic hack that can help diagnose. The best test is a back pressure gauge. There are also some vacuum gauge diagnosis.
George
Old Dec 2, 2022 | 12:28 AM
joseywales's Avatar
almost forgo this post was alive , anyway ive removed the cat and resonator and now exhaust is free , though it runs better i havent had time to deal with this one as it drives fine except up mountainous hills which isnt a problem really for me , i will be back to finish thios one after my other 2 are complete \, i bought a 2001 and a 96 for cheap boteh with issues and mainteance needs of course but we are getting through that , the usual gas tank , brake line leaks atec etc .soo you soon
bil2000
16
Sep 15, 2020 09:06 PM
Rleandro
Mar 8, 2018 04:50 PM
Tony Brown
Feb 3, 2016 09:00 PM
RandyRhoadsFan82
Nov 14, 2013 10:52 PM
1996BZR
19
Dec 23, 2008 03:07 PM
