p0305b
Old Nov 26, 2008 | 07:54 PM
rmv42158's Avatar
rmv42158 is an unknown quantity at this point
Default p0305b
#5 misfire. Finally got to scan the PCM. It tripped this code. Disty is lined up, tune up about 10k miles ago and it's idling bad, knocking (wood knock almost)but otherwise runs ok. Car sat for awhile prior to intake gasket repair. Ran fine before repair.I can smell coolant sometimes but see no leaks. I took #5 wires off engine, ran about the same maybe a little different with a bogging like noise but nothing like i thought it would. Starts and drives fine otherwise and no leaks or smoking that I can see. I have about had it with this thing.
Old Nov 26, 2008 | 07:57 PM
Default RE: p0305b
Check out the P0300 code in the DIY section. Much of the trouble shooting is the same.
I would check the resistance on the plug wire and pull the plug and have a look at it. Maybe run a compression test cylinder #5.
Old Nov 26, 2008 | 08:00 PM
blazin8556's Avatar
blazin8556 is an unknown quantity at this point
Default RE: p0305b
you want to sell it? i need a parts truck i think.i may need a tranny
Old Nov 26, 2008 | 08:04 PM
Default RE: p0305b
ORIGINAL: blazin8556
Great help right there...[&o]
Old Nov 27, 2008 | 11:00 AM
rmv42158's Avatar
Default RE: p0305b
Hah, Nah I'm gonna keep it sorry. Worst case I'll throw a Jasper in. Hate to do it since motor runs great otherwise. I'm going to try and do a compression check this week. Should I stop driving it?
Old Dec 5, 2008 | 05:39 PM
Default RE: p0305b
Please try to keep the discussion of your problem to one thread.
Have you performed the compression test? If so, what were the results? Have you taken a look at the P0300 Explained thread I mentioned above?
Old Dec 8, 2008 | 11:11 AM
rmv42158's Avatar
Default RE: p0305b
blazin8556
I have decided to sell.We boughta Denali soI don't need this anymore and frankly i just don't have the time anymore to play with it. you still interested? Runs and drivesok besides the slight miss and tapping.
