P0420 error code
Old Aug 24, 2009 | 06:41 PM
blacer2000's Avatar
blacer2000 is on a distinguished road
I am getting this Catalyst efficiency lowbank1 and I just put in a new air intake. Could they both be related? Or is the problem with the O2 sensors or the catalytic converter??? Are there are any tests I can do to isolate it to one thing? Can the code tell me which o2 sensor is??The car has just one catalytic converter.
Once I reset the computer it takes a couple miles for the "check engine light" to show up again, I don't really know if that is relevant. Also the car is running fine as far as I can tell. Thanks in advance for the help!!!
I have been reading around the forum and I see that a lot of people can tell which o2 sensor is faulty from the code? Did the scanner they used at autozone crap or am I missing something?
Old Aug 24, 2009 | 08:34 PM
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
Start there. This is not a code that directly indicates an issue with an O2 sensor.
Old Aug 24, 2009 | 09:12 PM
blacer2000's Avatar
Yeah I read that page and I was going the easiest way first which is to check out the o2 sensor before going into the catalytic converter. But how do I test the o2 sensors? There are 4 wires, one is ground, another is 12v and the other two I have no idea. Anybody know what the other two wired do and their colors? How could I check the cat converter?Taking it to a shop?Thanks for the help.
Old Aug 25, 2009 | 10:15 AM
blacer2000's Avatar
Also, does this mean that the code and the cold air intake have nothing to do with each other?
Old Aug 25, 2009 | 11:18 AM
I highly doubt the two are related.
Old Aug 25, 2009 | 11:35 AM
dpk1nb's Avatar
dpk1nb is on a distinguished road
If you have to replace one O2 sensor replace them both. Its not worth the trouble it will eventually cause to do one only
Old Aug 25, 2009 | 11:36 AM
blacer2000's Avatar
ok I will do that. Is there any way I can test them before changing them? Thanks
Old Aug 25, 2009 | 11:43 AM
dpk1nb's Avatar
Not sure how to test them. Ive only replaced an O2 sensor on an Intrepid. took it to a garage for the diagnostic then did the work myself. It fixed the problem i was having with that car.
Old Aug 25, 2009 | 05:53 PM
blacer2000's Avatar
ok so get this. I get from work turned the car off and then turned it back on once I was ready to test the sensors 5 minutes later so it was nice and hot. Then I get down there and start checking the 3 sensors with a voltmeter and it was fluctuating from about .2v to like .8v. It was doing it pretty steady and there was nothing weird so according to what I have read online these o2 sensors are in good working condition. So then I get back up and I noticed that the check engine light was off!!!! i turned the car off and then took it for a spin around the block and it's still off. What's going on here????
I had previously reset the computer and the same code came back twice. So how did it just come off??Any ideas??
Sensok
20
Jan 20, 2014 12:37 PM
98blazr
44
Aug 21, 2009 01:17 AM
lennyblazer
Jun 19, 2008 07:01 AM
abens
May 27, 2008 06:00 PM
gio17vani
Oct 27, 2007 08:43 AM
