P0446 Evap Code
Old Nov 7, 2013 | 12:29 AM
Foxcliffe's Avatar
Foxcliffe is on a distinguished road
Default P0446 Evap Code
Hello,
Well I have a P0446 code popping up on my 2000 Chevy Blazer. I know it's an Evap Emissions problem and I've started researching how to fix it. If anyone can give me some tips on fixing the problem while saving money (hopefully a DYI job, avoiding a big time mechanic), that would be awesome.
Any advice is greatly appreciated. I fear that I have to raise the truck up, which I don't have the capability to do, in order to fix the problem. Hopefully not.
Thanks in advance...
Old Nov 7, 2013 | 02:07 PM
abig84's Avatar
theres never really a answer for evap codes. when you bring it to a shop they will hook a scanner up and close the vent and then smoke the system with a machine and see where the smoke is leaking from.
i just searched that code on identifx and theres a pile of things it could be
  • Restricted Canister
  • Evaporative Emission (EVAP) Canister Purge Solenoid
  • Evaporative Hoses
  • Evaporative Vent Solenoid
  • Fuel Tank Pressure Sensor (FTPS)
  • Fuel Tank Pressure Sensor (FTPS) Wiring
15 - Fuel Tank Pressure (FTP) Sensor
3 - Evaporative Emission (EVAP) Ventilation Solenoid
1 - Fuel Filler Neck
1 - Evaporative Emission (EVAP) System Hose(s)/Line(s)
1 - Evaporative Canister
maybe bring it somewhere see how much to just tell you whats wrong with and fix it yourself.
start with the most easiest. see if your gas cap seal is cracked
Old Nov 7, 2013 | 05:33 PM
P0446 indicates there is an "EVAP vent circuit malfunction". This usually means electrical, but there could be a mechanical problem with the vent solenoid as well. The solenoid "lives" in an "unfriendly environment", (under the vehicle) and dirt can jam the valve. The flow chart in this link is straight from the GM "dealer issue" shop manual. Follow it, and it will take you right to the problem: https://blazerforum.com/forum/diagno...plained-35143/
Old Nov 10, 2013 | 01:07 PM
Foxcliffe's Avatar
Thanks for the great advice guys. It's really appreciated. Yes, accessing the exact problem is numero uno on the agenda. Hopefully it's just one issue on the list and not multiple.
Thanks again, all the best!
Old Jan 28, 2014 | 09:49 AM
Foxcliffe's Avatar
Default P0446 Code 2000 Blazer
Hello all,
I have an Evap error code P0446 popping up on my '00 Blazer. I've researched the problem and I'm taking the truck into the shop tomorrow to have them first, let me know the exact problem (for there are many possibilities), second, hopefully fix it.
I'm asking for any advice from someone who's had the P0446 error code. How much should I expect to pay or is there a customary fee? What type of parts might I have to purchase? Etc....
Thanks in advance for any light you all can shed on the subject.
Old Jan 28, 2014 | 10:30 AM
*Threads Merged* - Please keep to one thread per topic. Bumping of a two month old thread is much more appropriate.
Cost will depend on the findings from following the diagnostic tree provided earlier in this thread.
Old Jan 28, 2014 | 01:47 PM
spittybays
Guest
Posts: n/a
If your asking for the price of a diagnostic, in my neck of the woods it seems that between 75 and 120 depending on time spent and posted labor rate.
spongebobmac
May 1, 2011 08:50 PM
Arepok
Jan 28, 2011 12:36 PM
Jeru
Oct 20, 2009 08:09 PM
jpmccr
May 6, 2009 07:11 AM
truesmack
Feb 7, 2009 06:43 PM
