P0507 High Idle
Old Dec 10, 2008 | 03:19 PM
TRZR2's Avatar
TRZR2 is an unknown quantity at this point
Default P0507 High Idle
Have a 97 ZR2 Manual Trans and keep getting code p0507..replaced iac valve,turn off code,drive for about 80 or so miles and Service Engine light re-appears same code. Checked valve and connection lead.. all good...what am I missing? It all started when Icleaned the intake body with carb cleaner. I took oldiac and replaced it and cleaned the bore..should work..but can't shake the Engine light reappearing...any ideas??
Old Dec 10, 2008 | 08:26 PM
cr8390's Avatar
cr8390 is an unknown quantity at this point
Default RE: P0507 High Idle
The following items could cause this
An IAC valve which is stopped and cannot respond to the VCM
A throttle stop screw which has been tampered with
A damaged throttle or linkage
A slow, unstable, or fast idle may be caused by a non - IAC valve system problem that cannot be overcome by the IAC valve. tHE Out of range control IAC scan tool counts will read above 60 if the idle is too low and zero if the idle is too high.
Old Dec 18, 2008 | 11:06 AM
TRZR2's Avatar
Well...checked out things that you suggested, pulled IAC valve out and checked function..let idle re-set and drove...seemed good for a while..about 150 miles later "Engine" light back on..same code..could it be vacumn lines? Which test is it specificly on the analyiser for the valve fuction..mines is an Actron 9185 and should have all the functions. Thanks!! TR
cluckerr
May 16, 2012 09:25 AM
Kknd310
Dec 1, 2011 09:53 PM
mansopoor
Feb 27, 2011 04:58 PM
shaggy_5420
Aug 4, 2010 11:27 PM
michellesmark01
Engine & Internal
Apr 4, 2006 06:34 PM
