P0605 among others
Old May 21, 2022 | 01:52 PM
Mdz320's Avatar
Mdz320 is on a distinguished road
Default P0605 among others
This started out as a possible fuel filter or cat problem, but I found this code, noe I think different.
I was got a no start for about 30 minutes, then eventually I got it to idle.
Before that I had stalling at progressively lower speeds.
Old May 21, 2022 | 06:33 PM
LannyL81's Avatar
I had to look this one up...
wow...ECU/PCM fault. Suggest checking all the electrical connectors at the ECU/PCM for any corrosion on any of the terminals or if mice have gotten to any of the wiring.
Keep us informed if you find anything.
Good luck.
Old May 22, 2022 | 10:50 AM
Mdz320's Avatar
I made it home and let the truck sit a couple hours and went back out. Didn't start. Checked my fuel rail and had little pressure. Currently replacing fuel pump.
when it's up again I'll erase my codes and see what comes back. I'll check in then.
Old May 22, 2022 | 11:37 AM
Mdz320's Avatar
Just got word my fuel pump us in, and currently no codes. Will keep updating as I get more data.
Old May 23, 2022 | 06:15 PM
LannyL81's Avatar
Hope you are having a Delco fuel pump installed and not a cheap one....or you will be doing it over again.
I was driving on a highway, 65mph when I lost power. Coasted to the shoulder and I could get the engine to start, but if I tried to go above an idle...it would stall-out. This was when I got to replace the fuel pump in mine.
Old May 24, 2022 | 09:44 AM
Mdz320's Avatar
Carquest pump. I dont plan on keeping this another lifetime. Lots of rust in the tank.
Remaking codes
P0420 twice
P0440
P0442
P0446
P0605
P1441
P1870
U1026
U1041
U1042
U1192
U1193
Runs pretty ok considering everything.
Allen Gass
Oct 3, 2020 04:28 PM
Cassera
Aug 22, 2014 10:57 PM
shotnva777
Sep 23, 2011 05:54 AM
xCHIPx
Headers, Intake, & Exhaust
Nov 22, 2009 12:09 PM
jeffs91S10blazer
23
Aug 9, 2009 07:12 PM
