P235/75/15- LT235/75/15 are they the same????
Old Sep 15, 2009 | 03:54 PM
vrryder's Avatar
vrryder is on a distinguished road
Default P235/75/15- LT235/75/15 are they the same????
I have P235/7515's on my 99 blazer now and i want to buy 4 new ones. They only come in LT. I was told that LT235/75/15's are larger than P235/75/15. Is this true and will the LTS fit?
Old Sep 15, 2009 | 04:23 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
They should be the same size (235mm wide, sidewalk height 75% of width, 15" rim). Primary difference is heavier sidewalks so less tire sway and more load capacity. I have LT's on mine.
Old Sep 15, 2009 | 04:44 PM
vrryder's Avatar
So the LTS will fit on my rims where they have P's on them now?
Old Sep 15, 2009 | 05:00 PM
TripleBlackBlazer's Avatar
Yes.
P stands for passenger
LT stands for Light Truck
Old Sep 15, 2009 | 06:20 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
LT is just heavier duty with more cords and belts, which allows for greater load ratings at higher pressures. They will look bigger by a small amount like mentioned above because of the lack of tire sag.
Old Sep 15, 2009 | 11:03 PM
old skool luvr's Avatar
whoever told you the tires would be bigger needs to go back to school and re-learn their job. all i'm saying is, how can a tire that has the same numerical size be be different when it is preceeded by a "LT" instead of a "P"? hope you're not gonna buy tires from this guy vrryder...............
Old Sep 16, 2009 | 07:32 AM
vrryder's Avatar
No im not it was just someone in another forum thinking they knew something i guess.
Old Sep 16, 2009 | 07:46 PM
fenderfreek's Avatar
fenderfreek is an unknown quantity at this point
P=Passenger
LT=Light Truck
Just a weight rating.
Old Sep 17, 2009 | 10:47 AM
hkellogg's Avatar
hkellogg is an unknown quantity at this point
Lt tires ride harsher in my opinion I just put a set of p235-75-15 pirelli s orpion atr
Old Sep 17, 2009 | 11:08 AM
that's your personal opinion. if you never do anything with your truck-you should've bought a car! relax, i'm only joking.
seriously though hkellogg, if you never tow anything, or load your truck up alot, or do any serious off-roading, then passanger tires ("P" rated) are for you. yes ppl may say they ride harsher/rougher, but it's a truck (with a short WB) and they do tend to ride firmer than a car. it all depends upon the application, 'cause i'm running the same light truck tires ("LT" rated) on by old school 'Burb, and it still rides like a Cadillac, 'cause it has a longer WB.
laura8088
Tires and Wheels
Jun 20, 2014 08:32 AM
mikepro
Aug 15, 2011 07:03 PM
AmberRose
Aug 30, 2010 08:58 PM
vinniev
Tires and Wheels
Jun 9, 2010 09:52 AM
vrryder
Tires and Wheels
Dec 17, 2009 03:18 PM
