2 p235 70r 15 with 2 p235 75r 15
Old Jun 8, 2010 | 12:13 PM
vinniev's Avatar
vinniev is on a distinguished road
Question 2 p235 70r 15 with 2 p235 75r 15
Hi,
I have a 1993 s-10 blazer that now has 4 tires size p235/75r/15's on it. I can buy 2 new tires from someone real cheap but they are size p235/70r/ 15's. Can I put these 2 tires on the front and keep the 2 p235/75r/15's on the rear without causing any problems??
Thank you in advance for your help
Vinnie
Old Jun 8, 2010 | 02:50 PM
84BlazerS10's Avatar
I would think so just the 70 series will be slightly lower profile tire. But, I don't think it's enough of a change to hurt anything.
Old Jun 8, 2010 | 03:11 PM
TripleBlackBlazer's Avatar
I know for sure if you're 4wd you will mess all kinds of things up, your transfer case being number 1 (if you use 4wd).
What I'm not sure of is if the wheel speed sensors will like having two different sized tires and activating ABS.
Old Jun 9, 2010 | 06:40 AM
vinniev's Avatar
Thumbs up Thank you
Thanks for your help
To be on the safe side I will put the same size tires on the front as the ones that are on the back
Old Jun 9, 2010 | 09:52 AM
greatwhite's Avatar
greatwhite is on a distinguished road
I know on today's modern trucks puting on different size tires can screw up your transfer case. But I also know the oldies from the 70's and early 80's it wasnt as important lots of the old timers I know didnt care and never had a problem.
laura8088
Tires and Wheels
Jun 20, 2014 08:32 AM
teamrojas
Tires and Wheels
Feb 4, 2013 06:49 PM
vrryder
Sep 17, 2009 11:08 AM
