Parking brake
Old Aug 4, 2007 | 06:57 AM
pajama01504's Avatar
pajama01504 is an unknown quantity at this point
Default Parking brake
1998 s-10 blazer...OK, the parking brake never made a "ratchet" sound and worked fine, then the pedal would not stay down; I sprayed lube on it and it worked again for a good long time...but now the pedal does not stay down again...what is going on here?
Old Aug 4, 2007 | 07:35 AM
hillbillyinOhio's Avatar
Default RE: Parking brake
check your left rear wheel. take off the wheel and make sure that the parking brake is still making contact. the pins get worn back there (i think)
Old Aug 4, 2007 | 09:55 AM
Chevy Lover's Avatar
It could be that the parking brake ratchett assembly is worn and needs replacing. It could also be that the pedal is bent and no longer has the gears in the correct position to catch.
Does the park brake hold the truck if you keep your foot on the pedal?
Old Aug 4, 2007 | 02:44 PM
rriddle3's Avatar
Funny you should mention it,the e-brake on my '02 doesn't ratchet down, either. The pedal just moves like the regular brake pedal does and then locks. It obviously works though, it holds the truck in neutral on a slope.
Old Aug 4, 2007 | 08:43 PM
Right...I do not believe there is a conventional ratchet here....does anyone else agree?
Old Aug 13, 2007 | 01:22 PM
FirehawkNS's Avatar
FirehawkNS is an unknown quantity at this point
I bought my 01 blazer a week ago with the pedal doing this. It would brake, just wouldn't stay down. I replaced the assymbly instead of trying to figure out the spring. It took about 20 minutes total to do the job.
The part is $29 on gmpartsdirect.The GMpart number is 15016010 for 98-05 I think, just verify that it says it will work on your year.
Old Sep 8, 2007 | 08:14 PM
The lever works with a rack and pinion gearset....the pinion locks when you press the lever...that is why you do not hear the normal ratchet sound.....Thanks for the info on GM parts direct!...PM
xderkax
Jan 14, 2010 11:38 PM
SlimshagE
Mar 24, 2007 10:24 PM
ctstar2000
Mar 15, 2007 09:31 AM
blackknight
Feb 8, 2007 03:27 AM
J2K
May 29, 2006 10:50 AM
