Parking Brake :(
Old Jan 19, 2010 | 08:20 PM
panthersfan101's Avatar
panthersfan101 is on a distinguished road
Cool Parking Brake :(
My parking brake pedal was too tight, and wouldn't even go close to the floor. so, i loosened the cable to where it can go to the floor and tighten as it should... but the parking brake still wont engage. i could still drive perfectly with the parking brake down. it is really frustrating seeing as how my car is manual. the brake is fairly important. help!
Old Jan 19, 2010 | 11:12 PM
AJBert's Avatar
Sounds like something is frozen in the system. Time to tear into it and find out what's not working.
Old Jan 20, 2010 | 01:25 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Is this the procedure for adjusting the parking brake? I realize your truck is a lot newer than mine (94), but a properly adjusted brake probably won't make it to the floor. I just adjusted mine per the factory manual and it's perfect. I don't know about a 2004 though.
Old Jan 20, 2010 | 07:15 AM
well it doesnt go ALL the way to the floor. it goes to where it should. and tightens where it should... but no matter where the brake is, how hard it is pushed, no contact is made.
Old Jan 20, 2010 | 07:38 AM
Sounds like your cables at the back are froze up.
Old Jan 20, 2010 | 07:55 AM
DriftinBlzr's Avatar
DriftinBlzr is on a distinguished road
My mechanism inside the rotor was corroded and frozen on my '02. I finally got around to fixing it after 4 years of no parking/e-brake. Now the drum inside the rotors are rusty and don't hold very well. If it's not one thing it's another. You'll have to remove the wheel, caliper, and rotor to access the goodies inside. If you can get someone to push/release the parking brake you'll be able to see what moves and what doesn't.
Later, Doug
Later, Doug
Old Jan 20, 2010 | 10:12 AM
nj4x4blaze's Avatar
I have this same exact issue but I don't have drum brakes. How can one fix a frozen cable problem?
Old Jan 20, 2010 | 10:17 AM
You still have shielded cables at the back where the emergency brake cable goes into the internal drum brake assembly. You need to make sure that these are moving freely. If they are, then the problem is inside the drum (rotor hat).
Old Jan 21, 2010 | 06:59 AM
but i do not have drum brakes. i think nj4x4Blaze said he didn either. i have the 2004 model, which come with disk brakes! does that mean i still pull the wheels off and have a look? we were going to do that this weekend...
Old Jan 21, 2010 | 11:08 AM
Originally Posted by panthersfan101
but i do not have drum brakes. i have the 2004 model, which come with disk brakes! does that mean i still pull the wheels off and have a look?
Yes! The parking brakes are actually drum brakes inside the rear rotor. Pull off one of the rear rotors and you'll see what we're talking about.
Later, Doug
